TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-22-2017, 09:53 PM   #1
ssinister_l99
ssinister_l99's Avatar
Drives: 2011 Camaro SS Summit White
Can someone please help? Misfire?
Here is a link to the codes
https://youtu.be/f3dqouei4bo
I just removed my whole exhaust and swapped from kooks 1-7/8 headers to tsp 1-7/8x3 headers and from borla atak to corsa 3" zl1. I start my car and I get those codes (check engine, stabilitrak) and it's just running like complete shit. The car was on jack stands for probably s month and a half. I was putting back to stock but decided to keep it. So I got new headers catback, but not intake. I check my plug wires and everything was connected fine. I'm not too sure what's going on here. I drove around my block and it would shift very hard. Thanks!!!
D1sc procharger, gpi ss3 vvt cam, alky control, build 6l80e, tsp longtubes, corsa zl1 catback, eibach pro 1” springs
ssinister_l99 is offline   Reply With Quote
Old 03-22-2017, 11:26 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Cracked a spark?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 03-23-2017, 08:38 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Originally Posted by CamaroFred View Post
Cracked a spark?
+1..did you remove the spark plugs when workin on the headers? Very common and easy to fix....good luck
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 03-23-2017, 02:35 PM   #4
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Loose plug wire or cracked plug.
MMC is offline   Reply With Quote
Old 03-23-2017, 10:55 PM   #5
RankSS
Drives: 2010 Camaro SS
If it sat for a month and a half the battery is probably in need of a good charging.
These cars don't like low battery voltages.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 03-24-2017, 03:29 AM   #6
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
+2
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
