Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 08-14-2015, 06:22 PM   #1
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
For Your Information - Differential Part Numbers
I've been doing research the last few days gathering parts in the midst of my 3.91 install. Came across all the GM part numbers for bearings and seals and figured I'd share. The bearings all come with races. They're not hard to find with google. Anyhoo.....
Inner Pinion Bearing (big one inside the diff closest to the head on the pinion) - 20993936
Outer Pinion Bearing (smaller one next to the pinion seal) - 92243120
Crush Sleeve - 14012691
Carrier bearings - 92230402
Axle seals - 92230580
Pinion Seal - 92230584
All that being said, cheapest place to get them all in one package (that weren't possibly junk bearings) I found was from Lingenfelter (of all places) in a Master Kit from American Axle (maker of the Camaro OE diffs and gears) for $95. Buying it all separately from a dealer will run you probably north of $225-$250.
The AAM Master Bearing kit part number is 74060018. Comes with (2) Carrier bearings, (1) Inner Pinion, (1) Outer Pinon, and (1) Pinion Seal.
Rockauto has the best prices on axle seals and crush sleeves. I didn't need a crush sleeve as one came with the install kit I purchased but I figured to pick up and extra in case I over-torque one. Shipping prices blow but Amazon doesn't have jack in stock right now.
There's my f**k you Friday post because I care. A lot of people on here won't even change their own oil but for those of you wanting to wrench on your ride or save a buck or two (because those shits are valuable), here you go.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 08-17-2015, 02:12 PM   #2
LBJ
LBJ's Avatar
Drives: 2012 camaro 1LS. M6
Thank you.. that helps a lot of us
Mods..mrt v2. Cai intake v max throttle body. 20% windo tint & RX catch can Gianna 20in rims nitto 555 & afterburner tail lights RS halo head lights & gm heat extractor 4 pack gauges & panted heritage Grille & zl1rear sproler t5 splitter custom head rest
LBJ is offline   Reply With Quote
Old 07-20-2020, 12:59 PM   #3
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Very helpful info, thanks.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
bearing, carrier, differential, pinion, seal
