Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 10-13-2015, 07:13 PM   #1
bbturbo11
BBTURBO11
Drives: 2015 Camaro 2SS Commemorative
305's on stock rims?
Rocking 275s on my 2015 commemorative edition 2SS. Will 305's fit my stock rims?
bbturbo11 is offline   Reply With Quote
Old 10-13-2015, 07:17 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Sure they will fit, the question is whether it's recommended or not.
305's would likely be a bit much for a stock SS wheel. I think they are 9". For reference, the 1LE and ZL1 have a 285 on a 10" wheel.
You need to know the wheel width. Then you can check a site like tirerack. Look at the tire specs and it will show recommended wheel width.
JimE is offline   Reply With Quote
Old 10-13-2015, 08:40 PM   #3
bbturbo11
BBTURBO11
OK thank you very much!
Old 10-13-2015, 08:41 PM   #4
richard200593
richard200593's Avatar
Drives: 2012 45th Anniversary RS
Short answer is no. You more than likely have a 9 inch wide wheel and 305s require at least a 10-10.5 inch wheel.
*Performance:
mrt v2.0 exhaust/CAI Intake
*Cosmetic:
Zl1 factory Reproduction wheels
Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights
*Audio:
Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box
richard200593 is offline   Reply With Quote
Old 10-13-2015, 09:31 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Yep.
JusticePete is offline   Reply With Quote
Old 10-14-2015, 12:08 AM   #6
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
With a 9" wide wheel as yours are, 275s are as wide as you can safely go.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-17-2015, 05:59 PM   #7
bbturbo11
BBTURBO11
Thank you everyone
Old 10-17-2015, 06:08 PM   #8
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Originally Posted by bbturbo11 View Post
Thank you everyone
I have 295 40 20s on the rear of my car on stock rims. They look great and perform just as good. With just a little more sidewall the ride so much better as well. And you can really tell there's some meat back there
rontammy0 is offline   Reply With Quote
Old 10-18-2015, 04:20 AM   #9
98GTcoupe
98GTcoupe's Avatar
Drives: 2010 2SS Camaro
yeah Im running 295/40s they are great. no complaints no issues here, got about 5k on them now.
2010 2SS L99 Camaro-TSP headers, Vmaxx TB, CAI, Diablo intune, SOLO Mach X catback, tint, billet custom catch can, SLP Coil covers,SLP lowering springs, 295/40s out back ***SOLD***
Detailed with adams products!
2009 Infiniti G37 Coupe, tint....Stock
2006 GTO, R.I.P.
1981 Z28(sold)
98GTcoupe is offline   Reply With Quote
Old 10-18-2015, 12:02 PM   #10
unkillsam
Drives: 2012 Camaro LT
Can you go 255's on the rear 9". Just wondering for winter tire purposes. Thx
unkillsam is offline   Reply With Quote
Old 10-18-2015, 01:10 PM   #11
JusticePete
So your operate on the theory that if you don't wreck your car running on tires that are on a rim narrower than the tire manufacturer's specification sheet states is safe, you are doing it right?
Old 10-18-2015, 03:09 PM   #12
rontammy0
Thanks for the recommendation. .....where did I say that I'm not wrecking my car so it's safe. Look around on camaro 5 there are alot of members running a little wider tires on stock rims......let's not overreact .
Old 10-18-2015, 04:49 PM   #13
Synner
Drives: cars
When you state they perform just as good you're ignoring the pinched tire with reduced contact patch and creating a condition with increased sidewall flex on a heavy car that needs a stiff sidewall. Just as good is false. Sub-optimal would be more accurate.
Synner is offline   Reply With Quote
Old 10-18-2015, 05:25 PM   #14
JusticePete
What occurs with a tire in your configuration at high speed cruising speeds?
