09-07-2010, 11:58 PM | #1 |
Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
Has anyone ACTUALLY had a warranty denied due to tuning???
All this talk about voiding your factory warranty if you tune. I admit, I'm tempted to tune, but scared about losing my powertrain warranty too.
Is there 1 single person out there that has actually had ANY type of warranty repair denied because their have TUNED their car??? |
09-08-2010, 12:09 AM | #2 |
Drives: aqua 2ss l99 Join Date: Jun 2009
this should be good.
May your exhaust note, sing in harmony with your blower.
09-08-2010, 12:12 AM | #3 |
Voodoo Medicine Man
Drives: Black 2SS with RS package Join Date: Jul 2010
09-08-2010, 07:21 AM | #4 |
Drives: 2010 Red SS/RS Join Date: Jul 2009
crickets...
09-08-2010, 07:33 AM | #5 |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
WAIT JUST A DAMN MINUTE!
Why don't you preface the question with something about trying to warranty a blown engine or transmission. GM is not interested in whether or not you tune your car UNLESS you're trying to utilize your powertrain warranty for a major failure. So, the only people who should be answering the question posted here should be people who have grenaded an engine or transmission, because those are the only scenarios that GM is going to take the time to check for a tune. The whole mantra of "I want to flash it back to stock when I take it to the dealer for a dome light warranty!" is ridiculous. It just shows how much misinformation gets spread through the internet. |
09-08-2010, 07:42 AM | #6 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
09-08-2010, 08:23 AM | #7 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
If you tune it won't void the window motors or dome light just the powertrain.
I specifically asked a question to some GM folks I know about the tranny. Since mine was an earlier Vin and some of those had problems with the tailshaft breaking, I asked if my tranny broke would it be covered even if I had my car modded a little, especially when GM knew that some had problems. My answer was. " Highly Unilkely that they would cover the tranny on a modded car" Hopefully I never have to find out> |
09-08-2010, 08:30 AM | #8 |
Drives: 2010 Black Camaro 2SS/RS Join Date: Oct 2009
09-08-2010, 09:06 AM | #9 | |
Drives: '17 Fifty SS - '18 Traverse Redline Join Date: Jul 2009
Im curious on who will chime in on this topic
2017 Camaro SS -"FIFTY"
Mods: "93 Octane" |
09-08-2010, 09:08 AM | #10 | |
Drives: 2010 Camaro Auto Join Date: Mar 2010
09-08-2010, 09:18 AM | #11 | |
09-08-2010, 09:32 AM | #12 | |
09-08-2010, 09:35 AM | #13 |
Drives: 1999 Trans Am Join Date: Jul 2009
Good,direct question. I personally know of no one that has been denied. That includes a few that had lifter failures. It's tiring hearing people complain about the warrenties and tuning. GM has to prove the tuning caused the failure.
If you do have the car tuned just make sure it's done by a preffesional that knows what they are doing.Just like there are alot of good tuners, there are a ton of bad one's too. |
09-08-2010, 09:39 AM | #14 | |
Right, but the only time a tune would apply is in the case of a powertrain failure. People are going to sit here and assume that since nobody's responding, that having a tune doesn't cause a problem... However, the inherent flaw is that the number of powertrain failures is probably EXTREMELY low, meaning the sample set barely exists. The way the OP phrased it is not going to result in usable answers, since nobody's going to get anything denied for a tune other than a powertrain failure. This means all the people with a tune that go in to get something petty fixed will probably respond saying, "Oh, I got this fixed and have a tune!" and it's going to make people think they too can get away with it, even if they put a rod through the side of the block.
I'm trying to prevent people from getting a false sense of security about putting a tune in their car. FYI, I worked as a powertrain engineer for one of the big three... and warranty analysis was 50% of my day-to-day job. Quote:
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Warranty Work Denied...... not anymore? | Verio | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 18 | 11-30-2009 07:52 PM |
Who has actually had their warranty voided or work denied and why? | Tomato | 5th Gen Camaro SS LS LT General Discussions | 30 | 11-03-2009 09:16 AM |
Warranty WORK denied by Pontiac dealership | OUR72GTO | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 13 | 07-19-2009 05:24 AM |
Warranty Disclosure of Non-GM Products | odie23 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 10-10-2008 08:40 AM |
