01-21-2017, 12:10 PM | #1 |
Drives: '17 1SS 1LE & '15 Corvette Z06 Join Date: May 2009
Installed Winter MRR 228 Wheels & Tires
MRR 228's with BFG Goodrich A/S
20". Look for 2015 1LE sizes/offsets Wheel Description: Brand Name: MRR Model: M228 Size 20x10 F /20x11 R Camaro Bolt Pattern 5x120 Offset 23 F / 43 R Lip Size: N/A Color: Black Hub Bore Size: 66.9 Weight: 30.5lbs F /32lbs R Tires are BFG 285's all around (square set-up like the '15 1LE) 285-35-R20's BF GOODRICH G-FORCE COMP-2 A/S Ultra High Performance All-Season Size: 285/35ZR20 100Y Sidewall Style: Blackwall UTQG: 400 AA A ~$168 each on Tire Rack Last edited by bub; 06-28-2017 at 08:30 PM. |
01-21-2017, 01:48 PM | #2 |
Central PA Camaro5 Club
Drives: Hot Wheels Join Date: Apr 2009
Wheels look good
Hot Wheel SE # 343
01-21-2017, 03:57 PM | #3 |
Thanks. These are Gen 5 sizes all around (from our '15 1LE)
01-21-2017, 06:55 PM | #4 |
Use the Force
Are you running 30 or 35 series tires and the same size tire on all four corners?
Walk softly, carry a light saber and drive a ZL1!
01-22-2017, 08:18 PM | #5 |
01-22-2017, 08:26 PM | #6 |
Use the Force
OK thanks, looks good.
01-29-2017, 03:04 PM | #7 |
Overall pic. |
01-30-2017, 09:47 AM | #8 |
01-30-2017, 10:38 AM | #9 |
Drives: 2017 Camaro 1LE Join Date: Sep 2016
All black is great look man! Best looking "winter" set up I've seen.
02-19-2017, 03:32 PM | #10 |
02-19-2017, 08:51 PM | #11 |
08-03-2017, 12:58 PM | #12 |
Item of note - must use the black lug nuts that typically come with the rims, as the factory stock GM 1LE polished lug nuts are too big to mount on these rims (recesses for lug nuts in the wheels require smaller diameter lug nut heads)....
Center caps shown are glossy black GM (with bowtie) from Gen 5 Z28 P/N I think (came with wheel set from House of Wheels)... |
09-25-2017, 04:13 PM | #13 |
Drives: 2017 Chevrolet Camaro SS 1LE HBM Join Date: Jul 2017
After purchasing my glorious SS 1LE, my only means of private transportation year round, I find myself in a bit of a pickle as winter approaches and the restriction of the Goodyears operating in temps below 40 degrees. So, I'm glad this topic is on here and broadly discussed already. While it is a relief that Bub has already figured out a solution, which I may emulate, I really would prefer to keep the 285/305 arrangement. What I have found thus far is Pirelli P Zero All Season, but in 35 aspect ratio rather than the 30 of the Goodyears. Any of you have thoughts or input how a slightly taller tire could have any negative impact on the car? I do realize it likely will throw off the calibration of the speedometer but only slightly.
Thanks in advance for your thoughts. Larry |
09-27-2017, 06:27 AM | #14 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
I have the same set up. Speedo is 2moh off at 70.. getting some scrub in the rear.. i moved the harness but still get some scrub. Will pull them off today to verify what is touching. The drive good. Much quieter, smooth ride.update.. after a 1000 mile trip i did get some rub in the rear on dips at highway speeds.. i moved the harness but something did rub in the rear. Also only about a knife blade of clearance on the front tire to strut.
2017 1LE Hyper Blue
