Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 12-15-2013, 02:40 AM   #1
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Arrow build journal - '13 2ss/1le [COTW 8/15/16]
I’ve had the car a while and decided that I would finally start a thread.
The Car:
I knew I wanted an LE, but had not seen or driven one, but did drive an SS with the short throw shifter, nice to say at the least. I wanted a silver one, but they could not locate one with the options I wanted, they did have a Blue Ray Metallic on order without a sun roof. This is what I needed because otherwise my head rubbed the roof.
I put money down and this is what I got:
2SS/RS/1LE, Blue Ray Metallic, black interior, NPP Dual Mode Exhaust, Navigation, Heritage Grill, tint, extra cost front floor mats (nice really) and a trunk mat (heavy rubber ~ 30-40lbs, it makes a great standing pad in front of the workbench) and wheel locks. I also asked them not to mount the front license plate bracket.
Katherine and Ron picked it up 22May2013 (front and rear sub-frames show 10Apr build date), she was kind enough to send a couple of pictures from the dealership when she picked it up
Old 12-15-2013, 02:48 AM   #2
h018871
Geoff
h018871's Avatar
first time to lay eyes on it
Katherine put it in storage because we were staying in a hotel while waiting to close on a house. Here they are when I first saw the car 13Jun
Old 12-15-2013, 02:52 AM   #3
h018871
Geoff
h018871's Avatar
Mods
not sure if this is really a mod or not: installed the GM breather on the clean side of the PCV system
Old 12-15-2013, 02:55 AM   #4
h018871
Geoff
h018871's Avatar
Skip shift eliminator (had it purchased before the car was delivered). I had the car less than a week and installed it in the hotel parking lot. Backed up the handicap ramp in the afternoon (Houston in June……the car was HOT! Waited until the next morning, I did move the car so as not to block the handicap ramp. Barely enough room to get under the car, had to enter from the rear. Tight squeeze then could not get my arms up to the connector. Lots of squirming, a little bit of grumbling and I got it on. Scooted out from under the back of the car. Read the directions and figured out I had connected it to the backup solenoid, CRAP! Back under the car to remove and reinstall, it was much harder to get my hands and arms positioned so I could disconnect the skip solenoid, quite a bit more grumbling and a heck of a dent in my index finger later, it came off. Went on relatively easily, especially when compared to how the connector came off. Scooted out the back AGAIN, T-shirt rolling up my back. Brought back memories of working on cars when I was a few years younger (good memories), it has been a while since I fiddled with cars.
(Not really something I did, but I will count it): the front splitter did not fit very well, so took it to the dealer and they would remount/adjust it. Said it would take a couple of days. I said “a couple of days?!?!?!?”, he said yeah, he had to pull the front of the car off and lots of adjustments blah, blah, blah (my eyes glazed over). So I said “hey, can you give me a call when you get it off and I’ll come over and remove the front bow tie while you are there?”. He said he would get it done for me. Sweet, mod three done and I did not do anything except “smile and talk sweetly” (Thai saying of how to get things done). The dealer gave me a snazzy Malibu or Cobalt while I waited
Old 12-15-2013, 03:00 AM   #5
h018871
Geoff
h018871's Avatar
spare tire
I wanted a spare, mostly because when I get a flat, it is not the type you can repair with a can of fix-a-flat. So started researching the options and ended up getting two of them. 1st). I wanted to get the factory jack kit for a 2013 Camaro 1LT, this turned out to highlight a mistake in the GM documentation, although not a costly one (more on this later). Ordered the jack, wrench, handle, strap (what is that for?) and the tool container. I felt as though the 2013 factory kit would fit the trunk hole, not rattle, would fit the jack points and be able to lift the car…all good assumptions in my book. The parts to the kit started arriving to the hotel (still waiting to close on the house) and Katherine was starting to give me a bit of grief (good naturedly) about all of the boxes of car parts. I’d ordered mods for further ahead, but not able to install, so they do not get mentioned yet. Back to the jack kit, the wrench I received did not look like the picture. I did more research and found the owner’s manual on line (I did not look in the glove box) and it showed 2 jack kits for the car, coin/pierce and hex styles.
Old 12-15-2013, 03:03 AM   #6
h018871
Geoff
h018871's Avatar
I had the coin/pierce jack, extension and the hex wrench……..crud.
Old 12-15-2013, 03:08 AM   #7
h018871
Geoff
h018871's Avatar
The part numbers that were delivered all matched GM’s drawing, but did not work together as a “kit”. I went to my local dealer, asked to look in the trunk of a V6 that they had, salesperson looked at me a bit strange, but to his credit did not say anything. He asked what color, I said it did not matter (another strange look), got some keys and out to the lot we go. Popped the trunk and pulled out the spare and looked at the wrench. This one looked like the picture and I could see how it would work with the extension and the coin/pierce jack.
Took some pictures and put it all back into the trunk. Smiled and said “thx”, the whole story had been shared with the salesperson by this point. We had quite a laugh.
Old 12-15-2013, 03:12 AM   #8
h018871
Geoff
h018871's Avatar
spare tire, sorted
I then went to the parts department and talked to the expert behind the counter, he really was and expert, and gave him the equivalent of the Alice’s Restaurant Massacree. He said “hey, let’s look at another year, he picked 2010 and low and behold, there was the same picture/drawing, but a different part number for the wrench. I said “sold” for $20 (cheaper than shipping back to the internet company and the difference in the wrenches). So, if you have a hex jack without a wrench, I’ll let you have mine.
Still no tire, just a jack kit, the kit did fit in the spare hole, with the compressor (I did have to trim the foam of the compressor holder to clear the jack, but a nice no rattle fit). Back to the tire. I ordered a replica wheel, 10x20, and ordered the GY super gummy 285/35-20 to go on it. The tire ended up being backordered for 6 to 8 weeks, that is a long time but with my job schedule it would work out. Once the wheel arrived, I got to thinking that the 10x20 with a tire on it is BIG and the trunk is small. I pulled one of the front tires off and tried it in the trunk, tight, but it fit through the hole. Once it was secured with the strap (found this in the owner’s manual too) made the trunk fairly useless for anything more than a soft bag or two. SO, I looked at a temp spare and spacer for everyday use, found them and got ordered. I went with the Camaro set rather than the CTS-V, 100% because of the $$$ for the CTS-V wheel, it looked nice, but I could not justify it.
Three things of importance. First, the donut had to go in the hole, this means the compressor, can’t. Second, the GY super gummy was still on a 6 to 8 week backorder, even after 6 weeks. So, I switched to a DWS 275/40-20 that they had in stock to carry on road trips. Third, I needed a spacer to get the donut spare to work with the roller skate front brakes, ended up with a 2 ½ inch spacer. Easy
EDIT
more info on the spacer here: http://www.camaro5.com/forums/showthread.php?t=391084
Old 12-15-2013, 06:11 AM   #9
Kartashian
SoCal HT5
Kartashian's Avatar
Drives: The Punisher
Congrats man!!
Keep the mods coming...
Kartashian is offline   Reply With Quote
Old 12-15-2013, 04:51 PM   #10
h018871
Geoff
h018871's Avatar
Originally Posted by Kartashian View Post
Congrats man!!
thx mate
Old 12-15-2013, 04:55 PM   #11
h018871
Geoff
h018871's Avatar
cai
This kinda happened during the spare tire adventure. We were still in the hotel and I didn’t have any tools. Seeing the CAI sitting there was driving me crazy, I wanted to put it on. So I put the CAI box in the car (passenger front seat as it would not fit in the trunk) and went to Home Depot. Parked under a tree, w a y far away from the entrance and went in to buy a nut driver and an allen wrench set. Got the CAI installed in the shade of the tree, more nice memories.
When I first fired up the car, it stumbled and then settled down. But I got the dreaded CEL (check engine light), crud! Got online and emailed the manufacturer and learned that with the added airflow the computer had to “relearn” air fuel combinations. So I should disconnect the battery, just like the instructions said to do. Now, I read the directions thoroughly and carefully, I did notice that they included the step to disconnect the battery. I thought, why???? I am not going to do anything with the electrical system and I don’t want to have to reprogram the radio channels. So I left the battery hooked up. WRONG. I disconnected the battery, let it sit for a bit and then reconnected it. Set the clock and cycled the windows and all good! The radio did not have to be reset
RELATED ITEM: I lucked out because the car came with one of the “good” MAF sensors!
before and after:
Old 12-15-2013, 04:58 PM   #12
h018871
Geoff
h018871's Avatar
Somewhere in here I put on the front plate, because we got stopped one evening coming back from dinner. Apparently putting it in the front window is not good enough in Texas. The bracket I bought attaches under the splitter, so it is REALLY LOW and the plate gets dinged a lot.
Old 12-15-2013, 05:03 PM   #13
h018871
Geoff
h018871's Avatar
speaking of dinged
Wrecked 12Jul2013, a young kid on his cell phone pulled out in front of me (~2200mi on the car). Needless to say I was a bit irritated, but I did maintain my cool and no one was hurt. That is radiator fluid on the ground. It turned out to be only a broken overflow reservoir
Old 12-15-2013, 05:05 PM   #14
h018871
Geoff
h018871's Avatar
out of the car hospital
We picked up the car from the body shop when I got back 22Aug2013. Repair bill was $5500, gotta love insurance!
1le, 2ss, build, h018871
