Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 05-30-2014, 09:35 PM   #85
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
I've had this same problem 3 times on my 2011 SS. Dealer paid for the first 2, the 3rd I was responsible for. Well it happened again . So I ordered a gates belt with the tool and did it myself. Well its been 6 months and belt is still on.
meshamey is offline   Reply With Quote
Old 05-31-2014, 06:34 AM   #86
Bumblebee2012
Bumblebee2012's Avatar
Drives: 2012 2SS TF3, 1971 Chevelle
Where did you get the tool to roll the belt on?
Sent from my SCH-I605 using Tapatalk
Bumblebee2012 is offline   Reply With Quote
Old 06-01-2014, 02:23 AM   #87
Mando2776
Mando2776's Avatar
Drives: 2013 Camaro 2SS/RS
If I'm correct, it comes bundled with the belt kit. The gm brand does. Not sure if the gates brand comes with it or not.
Mando2776 is offline   Reply With Quote
Old 06-05-2014, 10:17 PM   #88
Fire65
Fire65's Avatar
Drives: 2011 2 LT RS Convertible
Boy am I glad I found this thread. I brought my 2011 V6 with 10800 miles to the dealer yesterday because of a squeal. I thought it might be the pulley. The tech wrote on the order that the squeal is "caused by aftermarket air intake causing crankcase pressure issues. Need to put back to factory will void warranty." Tomorrow I'll take a closer look at the ac belt. I've had a Vararam on it for a couple years without this issue.
Fire65 is offline   Reply With Quote
Old 06-06-2014, 05:18 AM   #89
Bumblebee2012
I've not heard of the belt issue with a V6. You'll be the first that I'm aware of If you find that your belt is walking part way off of the pulley similar to what is seen on the V8 cars in this thread. If you do see the belt walking, can you post a photo for other V6 owners to see? Honestly, if that's the case, you might also want to start a new thread so that the title of the thread says V6 belt issue or something.
Old 06-06-2014, 12:21 PM   #90
leafspring
leafspring's Avatar
Drives: 2010 2SS/RS White
I put the Gates belt on, did it myself, the belt and tool are sold separate, and are still cheaper than GM, it was a really easy install.
O'reilly's is where I got both tool, and belt, thousand miles now, looks like new yet, hopefully lasts longer than factory belt.
leafspring is offline   Reply With Quote
Old 12-08-2015, 01:05 PM   #91
oftenimitated
Drives: 2004 Honda Civic+2011 Camaro 2SS
2011 Camaro ss - just hit 12k miles and am having this problem...I can just cut the belt off for now right?? Its about to be winter here so Im in no hurry
This should be a recall by now with all the issues reported
oftenimitated is offline   Reply With Quote
Old 12-08-2015, 03:13 PM   #92
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
I had this exact same problem on my 2012 SS LS3. Purchased car brand new in 2012, AC belt shredded and had to be replaced at 8k. Never had an issue after the first belt was replaced.
Just this year I put an SLP 25% UDP on the car and changed the belt due to the smaller pulley...the new belt is strechy'er (if thats a word) than the stock AC Delco belt so it squeels if the AC is on in the rain once in awhile.
I think the belts GM used on the assembly line are just lower quality than the replacements...maybe a bad batch at the assembly plant, who knows lol.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 06-20-2017, 12:03 PM   #93
NSM1010
NSM1010's Avatar
Drives: 2011 Camaro SS/RS Convertible
Same here on my 2011 SS. Any idea on cause?!?! Only 4,300 miles!
NSM1010 is offline   Reply With Quote
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 01:45 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
