11-28-2016, 12:48 PM | #29 |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
Got rid of it on my GTO and 5th gen. It always seemed to get me when I was leaving a light behind a line of cars. I'd shift early and get blocked.
11-28-2016, 12:52 PM | #30 | |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
CAGS has been around since 1989, and the bypass harness has been around almost as long. If the EPA hasn't caught on by now they're exactly the clueless dopes we the thought they were. Also, it actually only affects the pollution output and fuel consumption at the exact moment and parameters the CAGS engages (or doesn't engage if the bypass is installed). Such an operation would never influence your car's readings at the emission testing station, unlike VW's diesel cheat which actively tampered with the inherent emission operations to show a different reading than what actually was taking place. |
11-28-2016, 04:03 PM | #31 |
Drives: 2017 2SS Convertible Join Date: Feb 2016
This. Every time. I had that harness installed within the first couple days of ownership, and now I can drive how I please. Different stories from different drivers due to different driving styles I suppose...
Nightfall Gray Metallic / Adrenaline Red / 6MT / NPP / MRC / 56V wheels 1100 - 07/15/16 3000 - 08/18/16 | TPW 09/05 - 08/23/16 3100 - 08/30/16 | TPW 09/12 - 08/30/16 3400 - 09/06/16 | TPW 09/05 - 09/06/16 3800 - 09/15/16 | 4200 - 09/20/16 6000 - 09/29/16 - on Camaro's 50th Birthday! |
11-29-2016, 08:45 PM | #32 | |
Drives: 2017 2SS - MRC, NPP, M6 Join Date: Jun 2016
Do you by chance have any clear instructions with how to install it? I have one now, but haven't installed it (1. can't get my car lifted enough to fit under it and 2. I've heard that it's easy to attach it to the reverse plug instead of the skip shift plug) |
11-29-2016, 08:56 PM | #33 |
I used to be Dragoneye...
I could dig up the instructions...but I don't know if things are all in the same place on the Gen 6 as the Gen 5...where did you buy it? Did it not come with instructions from that retailer?
11-30-2016, 09:02 AM | #34 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
I did mine in my garage. I have ramps, so got the front end high enough for me to get on my back to do it. The passenger side of the transmission tunnel is a bit tight fit to get my hand up there, but it was easy to unclip the existing connector. Putting in the CAGS eliminator it was easy to plug the harness into the lower connector, but the one up top it was a B*tch to get it properly lined up to push it back in for me. I was able to do it with a long blade screw driver. Whole thing took me maybe 15 minutes. There was a how to thread in the forum I found that helped.
I see the shift light most every time I take the car out too, so I really wanted this mod. And I also am glad GM came up with CAGS to get around the gas guzzler tax! |
11-30-2016, 01:46 PM | #35 | |
11-30-2016, 02:02 PM | #36 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
LOL, I remember doing the CAGS on my 98 Vette, as it was really annoying. When I test drove a 2017 SS, I didn't even know the skip shift mechanism was still in place, thought Chevy eliminated it. Maybe will need to get rid of it if it becomes bothersome.
11-30-2016, 03:07 PM | #37 |
Drives: 2016 camaro 1ss Join Date: Mar 2016
Yea so the autos have 4 cylinders cut out to save gas and the M6s have CAGS to save gas. But In all honestly has anyone ever even calculated and seen an increase in gas mileage with the CAGS? ! It's gotta be just a gimmick to get out of the gas guzzler tax.
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels |
11-30-2016, 03:26 PM | #38 | |
I will bite my lip before going on about that certain government agency that directs these tests and how I think it's great that a certain someone who was just elected might want to eliminate said certain agency or at least trim it down. |
11-30-2016, 03:43 PM | #39 |
Drives: 2016 SS Convertible Join Date: Sep 2016
Let's hope so !
12-01-2016, 09:58 AM | #40 |
Installation was very straightforward, but getting the top connector lined up correctly was a bit difficult due to limited clearance between the transmission & the transmission tunnel. I used a long blade screwdriver to help push it in the correct alignment, then it pushed right in.
http://www.camaro6.com/forums/showth...inator+install Last edited by BrianL; 12-02-2016 at 09:28 AM. |
12-01-2016, 12:59 PM | #41 | |
Thanks so much!!! |
06-11-2017, 11:25 AM | #42 | |
Drives: 2017 2SS Manual Join Date: Apr 2017
I used a long handled 90 degree pick tool. Probably would not have been possible for me without that tool |
