11-13-2023, 07:08 PM | #57 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
I can’t open it on my iPad or iPhone. Someone with more knowledge about Apple products can probably figure it out.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
11-13-2023, 07:53 PM | #58 |
Drives: 2023 Camaro 2SS 1LE Join Date: Sep 2023
This is fantastic. Thanks for doing this work.
I just had GREAT success copy and pasting the 2023 into the tool and finding my car. Really appreciate the work that went behind this as I'm sure many others will appreciate this. I'm sure if you could get Corvettes, etc, you could turn this into a very nice web site too!
2023 Camaro 2SS 1LE (M6) - Red Hot Coupe
2021 Camaro 2SS (M6) - Radiant Red Convertible (SOLD) Last edited by BSRacing; 11-13-2023 at 08:10 PM. |
11-13-2023, 08:59 PM | #59 | |
Drives: 2023 and 2024 Convertibles Join Date: Apr 2021
2024 3LT convertible Panther, M6, NPP, 6th non-ZL1 built, 95th overall
2023 1LT convertible Red Hot, A10, nicknamed "Rental" |
11-13-2023, 10:21 PM | #60 | |
Drives: 24 2SS CE M6 convertible Join Date: Aug 2023
its a zip file of CSV (comma separated values) format which is easily converted to XCel or other spreadsheet programs. that link should explain how to save the zip file to your ipad and then extract it. |
11-14-2023, 06:34 AM | #61 | |
11-14-2023, 08:28 AM | #62 | |
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper Join Date: Jun 2023
I found a few posted as vivid orange metallic but build sticker says Rapid Blue. Also noticed there's no Shadow Grey, I didn't go through all 34k units, but I'd assume there's more than just the first 2 Rapid Blues I've found. 1G1FH1R77P0100026 1G1FK1R6XP0100028 Also 1G1FJ1R6XP0142864 Listed as Black but is really a Shadow Gray Metallic Both came up as Vivid orange but are Rapid Blue according to build sheet.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531 Last edited by split_bumper; 11-14-2023 at 08:40 AM. |
11-14-2023, 10:00 AM | #63 | |
11-14-2023, 10:08 AM | #64 | |
Hopefully this will help some. Keep in mind they had two colours that are discontinued for 2024. Shadow Gray Metallic, and Rapid Blue. 2023 First and 2024 RPO codes 2nd.
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531 |
11-14-2023, 11:25 AM | #65 |
Hey radiator. I ended up getting it sorted out. I re formulated the color column to search for the RPO code. Should be all good to go on the 23's now.
I have updated main post, with a link for the 2023 Camaro Build info. Will add other years once we complete them!
11-14-2023, 03:50 PM | #66 | |
Drives: too many to say! Join Date: Nov 2010
When I download then open the 23 file, the colors get goofed up. I get "#NAME?" |
11-14-2023, 04:21 PM | #67 |
corrected color issue
11-14-2023, 04:40 PM | #68 | |
Should be good now.
11-14-2023, 05:57 PM | #69 |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
Same for 2022 !
2022 CAMARO LT1 COUPE AT10
11-14-2023, 06:07 PM | #70 |
only can get 20-24, working on 22 now
here's a partial list at least |
