Old 11-02-2017, 09:20 PM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Dyno day Saturday (11/4)... in for guesses!
2010 Camaro SS M6
stock bottom end LS3
AI 280cc LS3 heads
Ported LS3 intake
NW102mm TB
235/231 .6XX/.6XX 115LSA
Single 3" DP into dual 2.5 Borla exhaust with twin cutouts
Huron Speed Single Kit w/ Precision 7675 CEA .96 A/r
ZL1 pump / ADM FPCM / 1000cc injectors
Alky Control Meth 15 + 5 nozzles 100% meth
93 Octane
Plan is to push it to 16psi... hopefully Street Slayer Billet Twin holds up this time.
Dyno is Saturday morning (11/4). What you guys guess?
RealQuick is offline   Reply With Quote
Old 11-02-2017, 09:27 PM   #2
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Mustang or Dynojet?
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 11-02-2017, 09:30 PM   #3
RealQuick
Dynojet
Old 11-02-2017, 09:33 PM   #4
BiggFoot
BiggFoot's Avatar
So give us a hint to what your last dyno numbers were and what you have changed. I really don't know much about turbos.
Blower Cam
RPM Level VII
TR6060
Old 11-02-2017, 09:35 PM   #5
RealQuick
817rwhp @ 16psi with clutch slip and plug wire issues.
Same clutch... newer plug wires.
Old 11-02-2017, 10:00 PM   #6
BiggFoot
BiggFoot's Avatar
Ok I will go with 865 hp
Blower Cam
RPM Level VII
TR6060
Old 11-02-2017, 11:31 PM   #7
AGP Turbo
Drives: All things Turbocharged
Really just depends on how hard you want to lean on that meth system. 850whp if you run 16psi
AGP Turbo is offline   Reply With Quote
Old 11-03-2017, 04:41 AM   #8
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Originally Posted by RealQuick View Post
Dynojet
If your talking about Slowhawk dyno day in Bridgewater, it's a Mustang dyno...
Kopterman is offline   Reply With Quote
Old 11-03-2017, 06:58 AM   #9
RealQuick
Dez Racing in Seekonk, dynojet
Old 11-03-2017, 07:17 AM   #10
RealQuick
Leaning on it good from a fueling perspective, but timing is currently at 13psi pk tq and 15 deg at pk hp. I'll start there and see if I can squeeze more out of it.
Gonna try and overlay cutout off vs on for 8, 12, and 16psi.
Old 11-03-2017, 03:48 PM   #11
BiggFoot
BiggFoot's Avatar
When the shop tuned my car there was only ~ 5 hp difference between cut-outs closed VS. cut-outs open.
Blower Cam
RPM Level VII
TR6060
Old 11-03-2017, 06:07 PM   #12
RealQuick
Last time out at 13psi I saw 4Xrwhp/7Xrwtq by uncapping.
Uncapping a single 3" DP makes a big difference on a turbo car.
Old 11-04-2017, 06:34 AM   #13
BiggFoot
BiggFoot's Avatar
Good luck today . . . Please keep us posted!!
Blower Cam
RPM Level VII
TR6060
Old 11-04-2017, 06:57 AM   #14
RealQuick
Thanks!!! Leaving in 5 min. Gonna tune both my camaro and gto.
