Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 07-08-2017, 10:21 AM   #1
Grimlock
dey see me rollin
Grimlock's Avatar
Drives: the magic school bus
Shop recommendations for a spun bearing rod?
Hey guys,
Long story short it seems like I messed up something inside my engine. Starts up and makes the exact sound in the video. I am located in Maryland and am out of warranty. What's my best options for getting it fixed?
https://m.youtube.com/watch?v=AeB4UCaXAdg
Grimlock is offline   Reply With Quote
Old 07-09-2017, 07:50 PM   #2
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Depending on cost depends on options. If not to pricey, pay to repair. Limit running the car to prevent further damage due to bearing.
If you are at the top of your power range, a new motor might be in order, or rebuilt with forged parts.
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
edog is offline   Reply With Quote
Old 08-04-2017, 02:21 PM   #3
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Give us a call. We can get it looked at and get you taken care of.
Frans96ss is offline   Reply With Quote
