Old 08-24-2021, 07:59 AM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Smoked Rear Tail Lights/3rd Brake light and Marker light help.
Hi all, I have researched and researched and I am having a hard time figuring out which Smoked lights to get, I was thinking of the Hero Tail lights and 3rd brake lights what do you guys think of these? I don't like the idea of removing the bump as the car even though it is a 14 has no miles on it.
The marker lights I am not really hearing good things about any of them. any help would be great, I have researched a lot. Thanks
2014 2SS Aspen Grey.
Joe.G is offline   Reply With Quote
Old 08-24-2021, 09:39 AM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I've never been a fan. Looks great, not so great in practice as it reduces brightness.
In any case, aside from replacing the entire light, they make "tint kits" for most models. It's basically a tinted film that you apply.
JimE is offline   Reply With Quote
Old 08-24-2021, 03:43 PM   #3
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
Best looking mod for the rearend I think, hero tail lights and matching 3rd, and there is NO loss in brightness as they are LED and made to shine through, bright as can be, but you do have to remove the rear bumper, not as bad as I thought though
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
Old 08-24-2021, 09:00 PM   #4
Joe.G
Joe.G's Avatar
Vinman which Marker lights do you have?
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Old 08-25-2021, 06:01 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Looking good sir!!! Nice..
1JEWLDSSRS is offline   Reply With Quote
Old 08-26-2021, 07:43 AM   #6
Joe.G
Joe.G's Avatar
If I got a Pair of sequential ones can I disable that feature and make them work just like the Non sequential? I hear there is a Blue wire you connect together. They are hard to find at the moment.
SCT X4 Dynosteve,
Old 09-02-2021, 07:06 PM   #7
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
That looks EFFIN Sweet!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 09-02-2021, 07:26 PM   #8
Joe.G
Joe.G's Avatar
Do they work with LED Marker lights? the site says they do not.
SCT X4 Dynosteve,
Old 09-07-2021, 07:57 PM   #9
Joe.G
Joe.G's Avatar
Ordered the Hero Third Brake light, waiting for tails to get back in stock, Hopefully they work with the LED marker lights.
SCT X4 Dynosteve,
Old 09-16-2021, 07:52 AM   #10
Joe.G
Joe.G's Avatar
https://www.amazon.com/dp/B01M7RHH04...roduct_details
Ordered these, Hopefully they work with Hero tails and third brake lights.
Anyone know how to disable the sequential feature of the Hero lights?
SCT X4 Dynosteve,
Old 10-19-2021, 01:49 PM   #11
Joe.G
Joe.G's Avatar
No Issues with LED sides and Hero Tails, Only thing I don't like is the Delay between the Third brake light and the Heros, It's at least a second, I did put the Hero third on the flash pattern when it first turns on to try and take away from the delay.
Overall fit is nice, It curves in a bit more then stock where it meets the corner.
SCT X4 Dynosteve,
Old 10-19-2021, 03:56 PM   #12
vinman
vinman's Avatar
Stock markers, just tinted
Thank you!!
Yes, you can disable that feature
Thank you!!
UPSTATE C5 MEMBER
Old 10-19-2021, 03:57 PM   #13
vinman
vinman's Avatar
Sorry I haven't been on here much to reply
UPSTATE C5 MEMBER
