02-07-2014, 09:32 AM | #1 |
Drives: Camaro SS Join Date: Jan 2012
long tube header question
is it possible to install headers on your car without a lift? I got a couple ramps, probably raise it a foot, foot an a half...
02-07-2014, 09:36 AM | #2 |
Drives: 2010 2 SS Join Date: Oct 2013
Yes I've seen it done, get it at high as you can.
02-07-2014, 09:40 AM | #3 |
That's a good start. A good set of jack stands or ramps and a good jack will get the job done. Doesn't hurt to have a second jack and a helper as well. The higher you can get the car in the air the easier the job is when it comes to fitting the long tubes in.
02-07-2014, 09:42 AM | #4 |
Drives: 2000 Camaro SS Join Date: Feb 2010
Definitely. The higher you can get it the easier it will be through. Get a friend over to help. That will make it tremendously easier.
02-07-2014, 09:50 AM | #5 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
Did mine with my brother, front tires on 67 inch, 10 inch lift height 2 piece race ramps. It was a little tight getting the manifolds out but we made it work.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
02-07-2014, 10:56 AM | #6 |
thanks for the responses, does the car need to be tuned after or can I just drive it?
02-07-2014, 11:01 AM | #7 |
Drives: Chevys at the limit Join Date: Nov 2010
Just get it as high as you can and it can be done.
You can drive it afterword, the car will run fine, but you will need a tune sooner or later to get rid of the check engine light. Best regards, Tyler 888-308-6007 |
02-07-2014, 11:46 AM | #8 |
Drive Fast Take Chances
just did mine last week with jack stands,as stated the higher the better.
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/ |
02-07-2014, 11:56 AM | #9 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
You can just drive it BUT you'll throw CEL lights. Are you auto or manual?
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
02-07-2014, 01:49 PM | #10 |
Drives: 2010 1SS Join Date: Dec 2013
Definitely CEL. Mine came on right after I filled up at the gas station after 1 day and about 40-50 miles.
02-07-2014, 03:48 PM | #11 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
Still wait in' for the CEL on Pfadt Tri-Ys w/HF cats, CAI and SW retro chamber cat backs. Install last summer and 8,000+ miles ago, enjoy your new exhaust.
02-07-2014, 06:03 PM | #12 |
auto, does it make a difference?
02-07-2014, 06:19 PM | #13 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Not at all.
Most header kits can go on the car without a tune to start with. Probably will get some sort of SES light but nothing to worry about. Personally I wouldn't go beat the crap out of it before it was tuned...but it should still be safe. |
02-07-2014, 06:27 PM | #14 |
Drives: 2010 ABM 2SS/RS A6 and 2018 2500 Join Date: Sep 2010
Done mine on stands.You'll want to get that auto tuned as soon as you can.I ran mine for a while without being tuned without damage but the afm was annoying when it kicked in.
BLUETOOTH-SS
