03-19-2018, 08:29 AM | #1 |
Drives: 2016 Camaro V6 RS, 2005 Mustang GT Join Date: Sep 2016
1LE v6 suspension upgrade package?
Hey I'm looking to find a 1LE suspension package. Is there a package available for the b6? Or would aftermarket parts be a better option?
2016 Camaro RS V6, Custom Leather interior, Flowmaster American Thunder exhaust, x pipe
03-19-2018, 08:46 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
You can buy my ZL1 1LE suspension handling kit I have for sale.
http://www.camaro6.com/forums/showthread.php?t=523095 Pair that with the ball-jointed rear toe links the SS and above use and you'll have a much tighter handling machine with no loss of ride quality. As a rule, aftermarket suspension parts often mess up the bushing designs using polyurethane, which have unpredictable stiction, and/or poor weather-proofing design, like exposed spherical bearings that will rust and seize quickly. The OEM parts are very well designed in this regard.
03-19-2018, 09:54 AM | #3 | |
03-19-2018, 10:08 AM | #4 |
Hot Dog
You can run your existing dampers and springs, or choose something else (e.g. the GMPP lowering kit spring/damper combo). The links and bushings take the slop out of the FE2 soft rubber setup.
It definitely depends on your end-goal, but the FE4 and FEA hardware really tie down the chassis compared to FE3 and FE2 setups.
03-21-2018, 09:01 AM | #5 | |
Drives: 2016 1LT RS Join Date: Sep 2015
