Old 03-30-2017, 04:41 PM   #15
Snrub
Drives: Gone: 2017 Camaro SS
That's pretty amazing that you had the rates determined for yourself. That's gold star level forum participation.
Interesting that the rear rates are actually lower for the 1LE than for the SS.
Snrub is offline   Reply With Quote
Old 03-30-2017, 05:02 PM   #16
tecmec
Drives: 2016 2SS
Originally Posted by F1FTY View Post
Is that MRC or not?
Also, I'm new to this, but why does the label say 188.x, when the line itself seems to average just under 180?
Sent from my Nexus 6P using Tapatalk
tecmec is offline   Reply With Quote
Old 03-30-2017, 08:05 PM   #17
glenB
Drives: Chevrolet Camaro SS
Originally Posted by 00 Trans Ram View Post
Yeah - something is off on Eibach's site. Is N/mm right, or lb/in?
REAR
40 N/mm = 228.4 lb/in, not 121
121 N/mm = 690 lb/in, not 2691
I'm thinking that the correct rates are 40/228.4 and 121/690. This is obviously a progressive spring. Meant for comfort, not performance.
Also, I don't believe the stock spring is a straight 577 lb/in rate. It's probably progressive, too.
The stock springs are linear, front and rear, including the Performance Lowering Kit
glenB is offline   Reply With Quote
Old 03-31-2017, 04:43 AM   #18
F1FTY
Drives: 2018 ZL1
Originally Posted by tecmec View Post
Is that MRC or not?
Yes, the 1LE comes with MRC.
I'll ask the shop that did the test when I pick the springs up next week.
F1FTY is offline   Reply With Quote
Old 03-31-2017, 04:45 AM   #19
F1FTY
Drives: 2018 ZL1
Thanks! Sometimes if you want something done, you gotta go and do it.
It is! It does makes sense considering the rear swaybar increase. Will measure SS bars once the kit is installed for a comparison.
Old 03-31-2017, 08:52 PM   #20
glenB
The C6 base had a higher spring rate and smaller bar in the rear as well Vs the C6 Z51
Swapping out the rear 1le spring should be a 1 to 1 Vs the SS since the shock is separate. The fronts unfortunately is a different story because the MRC has a different spring pad height, or so I've read.
Old 04-01-2017, 07:45 AM   #21
F1FTY
Drives: 2018 ZL1
Interesting how GM does that to control the rear end dynamics between a sport setup and a performance one.
I was actually thinking about that the other night. If you have a 1LE, the rear SS springs might be an upgrade for you to get a little more oversteer.
If only we had MRC valving information between FE3 and FE4.
Old 04-01-2017, 02:25 PM   #22
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Thank you for the spring info! I'd like to see the FE3 and FE4 springs next to each other to see if they are the same height or not. I'm really waiting for someone with a non-1LE SS to buy the FE4 suspension kit and put it on their SS to see if it alters the ride height.
Eric SS is offline   Reply With Quote
Old 04-01-2017, 05:28 PM   #23
F1FTY
Drives: 2018 ZL1
That's coming next...
I plan on having the suspension installed this month and will do height measurements and add that information to the first post.
I'll keep updating this thread for search reasons and plan on also including swaybar sizes and rates for comparison too. Eventually, building a spreadsheet.
Also will be testing the factory SS springs from the FE3 so we have graphs to compare. Each test costs me $43, so not a biggie
Old 04-04-2017, 12:16 PM   #24
F1FTY
Drives: 2018 ZL1
Is that MRC or not?
Follow up to your second question:
The real rate on these is that center flat section. The ramp up are when the spring is being compressed to load or at coil bind and those numbers don't matter for our uses.
I've corrected the front rate down to 178 lbs/in to reflect this.
Big thanks again to RRT for getting this done and explaining the graphs to me.
Old 04-04-2017, 12:32 PM   #25
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I'll be adding factory SS graphs to this post in the future
Non-MRC SS Rates: 137 lbs/in (Front) 577 lbs/in (Rear)
Eibach Rates: 160 lbs/in (Front) 121-691 lbs/in (Rear)
1LE Rates: 178 lbs/in (Front) 539 lbs/in (Rear)
Eibach rear springs must be progressive
Factory SS and 1LE are basically linear
1LE Spring Rate Front
1LE Spring Rate Rear
Absolutely fantastic! Bravo for putting forth the effort to get the stock springs actually tested!
Wow only 3" of spring linear travel. Yikes. That's probably OK for the rear given it's motion ratio, but man that's very limited stroke up front.
Old 04-04-2017, 01:22 PM   #26
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Has anyone determined the ZL1 spring rates yet to compare?
Old 04-04-2017, 01:41 PM   #27
F1FTY
Drives: 2018 ZL1
Not to my knowledge. If anyone wants me to get them tested for them, PM me and we can work something out. The test costs $43.xx and during race season may take a week or two.
I'd expect higher front rate for the ZL1 due to engine/supercharger/cooling weight.
Old 04-04-2017, 01:42 PM   #28
F1FTY
Drives: 2018 ZL1
Thank you!
How did you determine the spring travel? What formula? Curious because I didn't know that could also be calculated from this!
1le springs rate
