05-07-2018, 06:10 PM | #1 |
Drives: 10 Procharged SS Join Date: Oct 2009
Oil Cooler Block Off Issue
Can anyone tell me how this coolant port works...........I'm wondering if I can bottom out a plug in this hole or if I need to leave room for coolant to flow by?
Thanks
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
05-07-2018, 06:17 PM | #2 |
Drives: cars Join Date: May 2011
You buy this.
https://www.texas-speed.com/p-233-gm...lant-plug.aspx |
05-07-2018, 06:19 PM | #3 | |
05-07-2018, 06:26 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
it opens straight into the block so yeah...it's open behind it...did you try wrapping a sh!t load of teflon pipe tape around the threads? I will be doing the same mod soon...and it is currently leaking a bit....
and I don't like havin to do stuff over again! keep us posted! peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
05-07-2018, 06:29 PM | #5 | |
05-07-2018, 09:20 PM | #6 |
Its a water passage for the block, don't plug it. Are the threads buggered?
05-07-2018, 09:46 PM | #7 |
Yes they are very much and now I'm really not sure what to do
05-08-2018, 02:45 AM | #8 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
that is a known issue from the factory for it to be xthreaded or not torqued. thankfully mine wasnt torqued. removed it with my fingers.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
05-08-2018, 07:16 AM | #9 |
You sure got lucky..... thankfully
05-08-2018, 07:22 AM | #10 |
There seems to be a stop tab in the back of the hole. Does anyone have a picture of this or diagram of the coolant flow that will show this tab? Mine is no longer there (shop decided to cut it out) and I think it's being blocked off.
05-08-2018, 08:46 AM | #11 |
are the threads stripped? if not last ditch use some JB weld! and use the original nut, the shoulder design stops it from going in to far...good luck!
peace...
05-08-2018, 09:21 AM | #12 |
Yes threads were so trashed from the factory that I bought a bigger plug (1” NPT) and stuck it in there. Bottomed the plug out and shot coolant everywhere. Backed off the plug this morning and used some rear diff gasket maker to seal the plug. So far I’ve gotten lucky this am and things are working great. I’ve got a tiny drip that I can live with and some stop leak may seal it. I didn’t want to pull this motor over something so small.
05-08-2018, 09:33 AM | #13 |
05-08-2018, 09:44 AM | #14 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
https://www.camaro5.com/forums/showthread.php?t=106511
There is a tap size mentioned in the TSB... G280X125N3 M28X1.25 E-taps.com Or https://drillsandcutters.com/m28-x-1...tric-hand-tap/ Ebay: https://www.ebay.com/itm/28mm-x-1-25...-/121802620212 -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
