Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 08-29-2012, 07:45 PM   #1
101fng
Drives: 2009 Mustang GT
ZL1 vs G8 GXP
ZL1: Stock
G8: Tires only
Ready.....
GO!
opinions?
101fng is offline   Reply With Quote
Old 08-29-2012, 07:47 PM   #2
Brettzel
Brettzel's Avatar
Drives: #null
Brettzel is offline   Reply With Quote
Old 08-29-2012, 08:24 PM   #3
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
I know, I know, start a fire under the ZL-1 kill it with heat soak and then the G8 would win.
L99CAMA2011 is offline   Reply With Quote
Old 08-29-2012, 08:28 PM   #4
LBV
LBV's Avatar
Drives: G8 GXP manual
585 hp vs 415 hp on the same platform with the same weight (give or take) = ZL1 win.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 08-29-2012, 09:45 PM   #5
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
This thread is full of win.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 08-29-2012, 10:07 PM   #6
101fng
looking at track times, i figured it'd be a little closer than the facepalms might suggest.
ok, so stock ls3's a no-go. cam and tires?
cut me some slack here, i'm ****ing LSx retarded. the big weight advantage plus tires seems like it could've been a good race. just bench racing here. and do me a favor, let's not refer to manufacturer hp ratings. i think we all know how accurate those are in the real world (especially when boost is involved)
Old 08-30-2012, 10:37 AM   #7
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
ZL1 should smoke it, BUT look at the times posted by real drivers. If the G8 can run 13's, it could very well win. There's a big difference between what Chevy says the car will run, and what it's actually running.
E.T. is offline   Reply With Quote
Old 08-30-2012, 11:59 AM   #8
101fng
that's what i'm saying. sure, low-12's have been had in a stock ZL1 but most of the time it's in the mid-12's. the G8 is a 13-even car stock, so how much would it really take to put it into the mid-12's (ZL1 territory).
Old 08-30-2012, 01:57 PM   #9
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Find me someone who's run 13 flat in a G8 bone stock. What GM says and real world numbers are totally different things.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 08-30-2012, 02:43 PM   #10
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
A well driven bone stock GXP on radials will run high 12s. An average driver will drive a ZL1 to mid-to-low 12s blowing the stock tires off.
http://www.dragtimes.com/Pontiac-G8-Timeslip-22332.html 12.93 at -6xx DA
http://www.dragtimes.com/Pontiac-G8-Timeslip-23400.html 12.95 with BMR Trailing Arms, Non-Adjustable Toe Rods, Poly Cradle Bushings, 1450 DA
http://www.dragtimes.com/Pontiac-G8-Timeslip-19751.html 13.12 with a dogshit 2.1 60'
http://www.dragtimes.com/Pontiac-G8-Timeslip-19252.html 13.16 with a 1.9 60' but a dogshit 2200 DA.
Please tell me you don't do much drag racing.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 08-30-2012, 02:52 PM   #11
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
those gpxs are quick
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 08-30-2012, 03:07 PM   #12
E.T.
E.T.'s Avatar
Looks like Motortrend got: 13.0 sec @ 109.6 mph
http://www.motortrend.com/roadtests/...t/viewall.html
There's a difference between mag times and what real drivers are going to get the first time they go to the track, though. I doubt an inexperienced driver would be able to pull off a time like that without some practice.
Old 08-30-2012, 03:13 PM   #13
motorhead
Why not just do a ZL1 VS prius thread. The result would be the same. Asswhoop'en either way.
Old 08-30-2012, 04:05 PM   #14
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
If the ZL1 is stick with an average driver the G8 has a reasonable chance.
DarkneSS is offline   Reply With Quote
