11-19-2020, 11:15 AM | #15 |
probably going to do 19s it seems like getting prices on 19x10 19x11 and 19x10.5 what do you guys seem to like more square setup or staggered? and we can run a 305/30/19 square no problem?
11-19-2020, 12:17 PM | #16 |
Drives: Camaro 1ss Join Date: Nov 2019
I run 19x10.5 at 305/30/19 squared no problem
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
11-19-2020, 12:33 PM | #17 |
gotcha thanks only shitty thing is ones im looking at are et 22 so i will probably have to run front spacer and extended lugs
11-19-2020, 12:45 PM | #18 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Apex has 18s that fit SLE brakes according their guide.
I was thinking 315/30/18 square. Was considering the Falken 660s but pricing is much higher vs 305/19 for some reason so I'll prolly go with A052s.
11-19-2020, 12:57 PM | #19 |
yea im taking seans advice up top figure out what size tires/brand first then think about wheels
my buddy just got some volk te37 18x10.5 and 295/35/18 yoko a052s and he loves em
11-19-2020, 01:09 PM | #20 |
you looking at the Apex wheels? I run the EC-7 +22, I do run the spacer up front with stock size studs.... Now I don't recommend running with the stock studs but it is possible. Idk if it really matters as the tire choices you are looking at are a bit more sticky than what I run but I'm on the Hankook RS4, seemed to be the longest life option for the 200tw category
11-19-2020, 01:24 PM | #21 |
i looked at apex and also at volk racing and also hre wheels altho they dont offer a 19" wheel in the flowform line
i was told for 19x10.5 et 22 i would need spacer and extended lugs in front
11-19-2020, 01:32 PM | #22 | |
I thought I read somewhere we can use truck studs as a cheap alternative to the ARP studs. I have no idea if this is true though.
11-19-2020, 01:43 PM | #23 |
I measured that you can use up to 5mm spacers up front, at least on my SLE.
I needed 7mm for my winter wheel setup so I installed 1" longer ARP studs, if you cut the nose off you can also fit the stock setup w/ closed-end lug nuts.
11-19-2020, 01:46 PM | #24 | |
295/35 are a little closer to OEM diameter, but not sure if that matters much if all 4 are the same diameter.
11-19-2020, 01:56 PM | #25 |
yea i heard 20mm my buddy is doing 19x11 and he has to run extended lugs and spacer
11-19-2020, 04:40 PM | #26 |
I agree 18s or 19s depends on which tire you want to run. I've been running 19x10.5 ET22 305 true square all year with the G3Rs. It's great to be able to rotate to all 4 corners.
Longer studs in the front are required even with a 5mm spacer in my view of what's safe for min thread engagement. The front studs are a breeze and you don't have to take off the rotors etc. |
11-19-2020, 04:43 PM | #27 | |
my buddy is running same setup right now but he is going to 19x11 squared and i guess the arp extended studs are on backorder right now
11-20-2020, 06:26 AM | #28 | |
https://www.rockauto.com/en/moreinfo.php?pk=9841348
