01-30-2017, 01:47 PM | #29 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
02-02-2017, 12:30 PM | #30 |
Drives: None Join Date: Nov 2016
Master cylinder replacement did not help. Dealership ordered the slave cylinder and will be trying that tomorrow. There are only so many components in a hydraulic clutch setup. Fingers crossed that this is it.
Dealership continues doing a good job and staying on this for me.
-Brian
Hyper Blue 1SS / 1LE Last edited by Sleeks; 02-02-2017 at 12:48 PM. |
02-02-2017, 12:41 PM | #31 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
Thanks for the update. I hope replacing the slave cylinder too would fix it!
02-02-2017, 01:38 PM | #32 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Pedal --> Master --> Hose --> Slave --> Throwout bearing --> Pressure Plate Frankly I'm not sure how it left the factory.
02-02-2017, 02:00 PM | #33 |
Drives: corvette Join Date: Jan 2017
If you want some interesting reading google turkey baster clutch stuck pedal. I am not sure on Camaro's but corvettes have had a lot of this same issue in the past. You dealer is doing exactly what mine did. If it is the same problem, after they slave does not fix it they will want to put in an aftermarket return spring. Hope you have better luck
02-02-2017, 02:39 PM | #34 | ||
Like I said previously, GM and the dealer are taking this seriously and working to fix it, so I have nothing to complain about at this point.
-Brian
Hyper Blue 1SS / 1LE |
02-07-2017, 12:27 PM | #35 |
Dealer just called. Car is fixed, will be picking it up tonight.
Here is all the work that was done. Kudos to my dealer for sticking with it and driving to conclusion. 1. Bleed the system/check the pedal assembly - no change 2. Install a new master cylinder - no change 3. Swap the clutch valve with one from a working car. (circular piece that is inline behind the pedals. It was pictured earlier in this thread) - no change 4. Swap the pressure plate and slave cylinder - fixed. Dealer received authorization from GM to do both since the transmission was out of the car. Not 100% sure which thing fixed it, but it is fixed now. I'll confirm that all is well when I pick up the car.
-Brian
02-08-2017, 11:07 AM | #36 |
Thank you for the update. Now I know what to expect...
02-08-2017, 01:03 PM | #37 |
And I can confirm it is fixed. Everything is great. Dealer believes it was the pressure plate.
-Brian
02-10-2017, 01:04 PM | #38 |
Drives: Chevy Camaro Join Date: Dec 2014
Glad to hear the dealer resolved your issue. Our money would be on the pressure plate as the culprit. If the PP fingers were defective it could definitely cause the slow engagement.
10-05-2018, 08:25 AM | #39 |
FINALLY took mine in...
1. Replaced master cylinder and bleed - problem still exist. 2. Replaced check valve after the master cylinder - still exist. 3. Remove transmission and replaced clutch actuator (slave cylinder) - FIXED. |
