05-03-2016, 09:02 PM | #1 |
Drives: 16' Supercharged 1SS Join Date: Apr 2014
Got my car back from the recall!!!
Took it in last Wednesday and got it back today! They said they took it all apart and had it on the lift and were waiting for the Bolts to come in because they got all the other parts before the bolts.
Got the bolts today and they put it all back together, she's finally home in the garage. Is there anything I should look out for now? Since it was such a big job I'm scared. |
05-03-2016, 09:05 PM | #2 |
Drives: 2016 camaro 2ss NGM Join Date: May 2015
ah now I am worried, take my car this saturday...
05-03-2016, 09:26 PM | #3 |
Drives: 2016/SS Has had 4 Gen 5's Join Date: Dec 2015
How does One know if his car is apart of the recal ???
SnoWhite |
05-03-2016, 09:40 PM | #4 |
Drives: 2016 Camaro 2SS Join Date: Jan 2016
05-03-2016, 09:42 PM | #5 |
You can check your vin here https://my.gm.com/recalls
Also, there's a possibility your vin is flagged, doesn't mean your car absolutely has to have it done, they'll check for it. |
05-03-2016, 09:44 PM | #6 |
05-03-2016, 09:47 PM | #7 |
Drives: 2SS - Hyper Blue/Ceramic White Join Date: Dec 2015
I take mine in on Thursday, I hope they don't keep it more than a day. Definitely want to get it taken care of ASAP. I was notified by OnStar and received and letter.
2SS - Hyper Blue/Ceramic White, A8, MRC, Npp, Sunroof, Low-Gloss Black Wheels, White Rally Stripes.
05-03-2016, 09:48 PM | #8 |
Drives: 2020 Elkhart Lake Blue 1LT Z51 C8 Join Date: May 2009
Check your coolant level. When they pull the pan, oil cooler lines have to be disconnected. I forgot to check mine when I picked it up, coolant was low since some obviously came out when the pulled the oil cooler lines. I filled it back up and everything is fine, no coolant leaks.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!! Sold 9/17/19 :( 2020 C8 ordered!! "The greatest sound in the world is a Rolls Royce Merlin over 100 inches" www.timadamsphotography.com |
05-03-2016, 09:52 PM | #9 |
Took them a week for mine. They don't have the parts in stock, they're on GM restriction so they have to send pictures over to the engineers in order to even get the parts... :/
05-03-2016, 09:54 PM | #10 | |
05-03-2016, 09:57 PM | #11 | |
or the yellow stuff in the back right? |
05-03-2016, 10:00 PM | #12 |
Look at the big tank on the left side of the motor. You can miss it. It's on the same level as the engine cover. You can see the coolant right thru it. It has two fill points. When cold the top part should be filled to the brim, the bottom part of the tank should be 1/2 full. Dex-Cool 50/50. That way you don't have to worry about mixing water and coolant 50/50, it is already done for you.
05-03-2016, 10:01 PM | #13 |
Pink, yellow cap is the brake fluid.
05-03-2016, 10:04 PM | #14 |
Retired from Car mfrs....
Please check out the manual if you dont know where your fluids are....
