04-12-2016, 09:18 PM | #1 |
Drives: 2016 Camaro SS NPP Join Date: Mar 2016
Light rattle when shifting from 1st to 2nd
Just wondering if this is normal? I have a 2016 m6 and sometimes when I shift from 1st to 2nd gear or even to 3rd, at low speeds I hear a light rattle metal sound after releasing the clutch. Anybody else experienced this noise? Or am I doing something wrong? Some help would be appreciated. Thanks
Ps car has only 400miles |
04-12-2016, 09:39 PM | #2 | |
Drives: 16' Camaro 2SS Join Date: Nov 2015
The day I test drove it I was told it's nothing...just needs to warmed up. I told them to have it inspected before I pick it up and they said they did and service found nothing wrong with it. I've got 3000 miles on it now, it hasn't gotten worse or better. I'll let you know once I do have it inspected again.
2016 Camaro 2SS\Jet Black\6MT\NPP\MRC
04-12-2016, 09:57 PM | #3 |
Good to know its not just me, the same as you described. This is my first manual so I'm not sure if that's normal or not. Please let me know what the dealer says after the inspection, thanks for the input.
04-12-2016, 09:59 PM | #4 |
Drives: Slow Join Date: Mar 2016
If it's when the clutch is disengaged, it may just be clutch/driveline chatter. My 350z was terrible about that at a stop when I switched to a 6 puck clutch/lightweight flywheel, never heard it while driving though. Do you hear it in neutral with the clutch disengaged?
2016 Toyota 4Runner
2017 Camaro ZL1 |
04-12-2016, 10:06 PM | #5 |
Drives: 2016 1SS Yellow Join Date: Aug 2015
I have the same issue.. Not really sure if it's an issue or not.. But it happens when I m in first gear.. Low rpms.. I press in the clutch to move into second... N that's when it feels like something is wrong... I dismissed it as something to do with flywheel... Not sure but if it is a genuine issue
1SS,Yellow,Gray Wheels,Black bow ties,NPP.
04-12-2016, 10:50 PM | #6 | |
04-12-2016, 10:56 PM | #7 | |
04-12-2016, 10:59 PM | #8 | |
I had the tr6060 in my ls3 c6, it never had any sort of issue with the trans, it's a stout unit.
2016 Toyota 4Runner
2017 Camaro ZL1 |
04-13-2016, 03:10 AM | #9 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
I hear it too. I believe it is driveline chatter and nothing to worry about. I hear it also when backing up a slight hill into my garage at home while having to do the very slow reverse-clutch in/out dance. When I back in with my drivers window down I can hear it amplified off the wall next to me.
04-13-2016, 06:51 AM | #10 | |
04-13-2016, 06:54 AM | #11 |
Ok on my way to work I tested it more and it usually shifting from 1st to 2nd I feel the shifter in sync with the metal noise, also happens with the skip shift bs from 1st to 4th. I also noticed when releasing the clutch extra slow from 1st to 2nd it is less noticeable.
04-13-2016, 07:09 AM | #12 |
Drives: 2016 camaro 1ss Join Date: Mar 2016
Thats funny I was about to create a thread soon myself but I guess it's normal?
When I'm in first at low speeds and press in the clutch I here chatter noise. Heard it since I bought it with 3 miles. Got 900 now. |
04-13-2016, 07:13 AM | #13 |
Is it the same with rev match on and off?
04-13-2016, 07:52 AM | #14 |
SABIO
Hey.
I will add myself to the "Me Too" List. I am not concerned. It is audible in low rpm shifts or slow shifts. If the RPM is higher amd quicker shift I do not notice it.
