03-23-2020, 04:01 PM | #1 |
Drives: Chevrolet Camaro Join Date: Mar 2020
Help with Brake INFO
So I have a 2012 Camaro SLP585 and it came with Brembo brakes. The calipers show Chevrolet and Brembo on each one. I know from SLP that the part numbers for the calipers are 37450 & 37451. I'm trying to find replacement part number for the brake pads. I'm asking everyone here to see if someone knows
Thanks |
03-25-2020, 05:27 PM | #2 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
The way I find parts is this: go to gmpartsdirect dot com and go through and find the parts/part number for your vehicle. You can then take the part number and shop around.
Hope this helps Sent from my iPad using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
03-25-2020, 06:09 PM | #3 |
Brakes
The only differecnce is the OEM parts for my Camaro are not the same as the Brembo brakes SLP installed as part of thei.r package
03-26-2020, 05:35 AM | #4 |
Are they possibly 6 piston?
Orange Krush II
03-26-2020, 06:02 AM | #5 |
Not sure just have part number from SLP haven't had time to pull the wheels and pad to look. I'm thinking 4 piston myself.
