Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-03-2018, 12:29 AM   #1
cliffdog89
cliffdog89's Avatar
Drives: 2LT/RS M6 '12 Camaro
Installing new clutch and flywheel torque specs
Hi All,
Installing a new OEM clutch, flywheel, and slave cylinder in my 2012 camaro manual transmission PN 24272326. I believe this is the Aisin AY6.
Below are the torque specs I have found online. Can anyone confirm these as correct?
Flywheel Bolts - First Pass 20 N.m 15 lb ft
Flywheel Bolts - Second Pass 50 N.m 37 lb ft
Flywheel Bolts - Final Pass 100 N.m 74 lb ft
Flexplate/Flywheel Bolts Threadlock 12345382 10953489
Slave Cylinder = 30 Nm
Also, is there anything I should keep in mind or be aware of during the process?
cliffdog89 is offline   Reply With Quote
Old 06-03-2018, 06:46 AM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Those are the correct specs. I'd put in a remote bleeder a minimum...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 06-03-2018, 04:28 PM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
If anyone has never pulled a trans in our cars, and has never had to bleed the slave cylinder, please take the advice given 100+ times on this forum and purchase a remote bleeder. Tick makes one that can be installed without removing the transmission, for those that dont need to pull it.
Bleeding that slave yesterday, was the worst shit ive done in a while. It sucks. Worse than pulling the trans and the rest of the entire job. Never again!
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
2012 camaro, 24272326, aisin ay6, torque, v6 camaro
