07-17-2015, 01:58 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Rebuilding Stock Calipers During powder coating
Which seal brand did you go with?
I am having mike the powdercoater do my front and rear brembo's and figure at 40k miles id better just have them rebuilt. What are your thoughts? https://www.rockauto.com/catalog/raf...make=CHEVROLET ^^^To use this link you then have to choose your year, model (Camaro), Engine Size, Then Click on "Brake/wheelhub & then on Caliper Repair Kit. Last edited by Nighthawk89; 07-18-2015 at 12:41 PM. |
07-17-2015, 09:49 PM | #2 |
Anyone?
07-17-2015, 10:20 PM | #3 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Not sure what happened to your link. I'd like info on doing a rebuild myself.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
07-18-2015, 09:04 AM | #4 |
Drives: '12 2LT Convertible Join Date: Mar 2012
The GM ones are fine.
You can also get them from racing brake. Maybe you can send the parts to Mike??? He is top notch. Highly recommended.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
07-18-2015, 10:12 AM | #5 |
US Veteran
The part numbers for a Brembo rebuild kit (GM) would be great if anyone has that info.
07-18-2015, 11:07 AM | #6 |
Drives: Black 2011 2SS/RS Join Date: May 2011
If Mike's doing them they will come back rebuilt. Mine did.
07-18-2015, 11:42 AM | #7 |
Drives: none Join Date: Apr 2014
+1 on the gm part number. Im powdercoating a bunch of sets for people in my local area and want to make sure what i have on order is correct
07-18-2015, 11:44 AM | #8 |
He rebuilds your stock ones with what youve got. Not with new parts.
I have the GM parts #'s and at 118 for some rubber i am highly skeptical. Mike recommeneded rock auto either the centric or carlson. I just wanted to see which one people had gone with? |
07-18-2015, 11:46 AM | #9 |
Brembo Front Caliper Dust Shield Rebuild Kit part # is: 89047722$23 ea.
Brembo Front Caliper Piston/Seal Rebuild Kit part # is: 92244294$43 ea. Brembo Rear Caliper Dust Shield Rebuild Kit part # is: 89047739$14 ea. Brembo Rear Caliper Piston/Seal Rebuild Kit part # is: 89047731$38 ea |
07-18-2015, 11:52 AM | #10 |
Carlson is the top 2
Centric is the bottom 2 You would either need 2 of each of the top Or 2 of each of the bottom. |
07-18-2015, 01:36 PM | #11 |
Gotcha. Mine were new when I sent them in.
07-18-2015, 02:09 PM | #12 |
07-18-2015, 04:47 PM | #13 | |
US Veteran
Thumbs up!
07-18-2015, 05:05 PM | #14 |
