09-19-2021, 09:52 PM | #1 |
Drives: 2016 2ss Camaro Join Date: Oct 2016
Help Camaro ZL1 2017 over heating
I have a 2017 zl1 and it keeps over heating I’ve replaced thermostat once already and it seems like it’s doing the exact same thing as when the other one went out not sure what to do but the fan will stay on 10 mins after car is off and the temp will get to one notch before 260.
09-20-2021, 01:43 PM | #2 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Do you still have a warranty for this?
09-20-2021, 07:41 PM | #3 |
I do not, the car has mild bolt ons
09-20-2021, 08:19 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Is the coolant filled to the proper levels? Is there any leakage anywhere?
09-20-2021, 08:23 PM | #5 |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
Air in the cooling system?
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
09-20-2021, 08:57 PM | #6 |
Drives: 2019 ZL-1 Join Date: Feb 2009
If not filled correctly and burped the ZL1 can overheat since it produces so much energy.
2012 Yukon XL Denali w/ 6.2 AWD |
09-22-2021, 09:03 AM | #7 |
Thank you Al Oppenheiser!
OEM thermostat? (some of the aftermarket are shit, particularly MM)
09-22-2021, 08:35 PM | #8 |
It’s filled and burped it is an aftermarket thermostat billet with a company called moto rad, my fan will run 10 mins after my car is even off. Has anyone had their water pump
Go out? I don’t know what else it could be |
09-22-2021, 08:39 PM | #9 |
Go back to the OE waterpump....and housing
09-22-2021, 08:44 PM | #10 |
It will end up one notch before 260 if I’m just cruising around but doesn’t do it right away just after cruising for a little
09-22-2021, 09:40 PM | #11 |
I had my water pump go bad on my 06 GTO. It overheated while sitting at a drive through but then went back to working normally until the dealer confirmed it was bad.
When you first replaced the thermostat, was it the original one? |
09-23-2021, 09:52 AM | #12 |
Drives: 2020 ZL1 1LE A10 Join Date: Feb 2021
Put the stock t-stat back in, reburp the coolant system and test again. Chances are the moto-rad t-stat you are using is not opening and closing properly.
09-23-2021, 11:05 AM | #13 |
Drives: 2017 ZL1 Join Date: Apr 2020
This
2017 ZL1 M6 Silver Ice Metallic
09-26-2021, 08:47 PM | #14 |
Thanks guys I just ordered the stock housing, and ordered a 175 kaytech thermostat
