dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 09-24-2009, 10:15 PM   #1
sav1
sav1's Avatar
Drives: 2009 Corvette Z06
DIY - ENGINE COVER PAINTED
Ok, so I was contemplating buying a painted engine cover (RED) from GM, or Doing it myself.. If I bought one. It would cost $380, and WASTE a perfectly good engine cover. Plus, the GM engine cover is really bland looking. So I collected up some info on C5 and decided to do it myself.. So if your wondering about buying one or DIY... and you think this came out ok... go for it.. PAINT.
remove the heat shield from the bottom
Cleaned / Degreased
sanded (NOT chevrolet letters)
CLeaned / Degreased
masked (4 hours - I'm extremely anal)
800 grit Sand
Cleaned / Degreased
Base coat (high heat 500* Duplicolor)
Wiped off "Chevrolet" letters with wet paint thinner LINT FREE towel
Cleaned lettering with wax / degrease remover. (see pic)
Dry (24 hours)
Clean / Degrease
WET sand (1500 Grit)
Clear Coat (high heat 500* - This clear does NOT make it Glossy)
Cleaned / Degreased
WARNING - If you're looking for a Glossy finish, don't use this paint or clear.
sav1 is offline   Reply With Quote
Old 09-24-2009, 10:26 PM   #2
Tecca
Tecca's Avatar
Drives: ...
Nice write up however I highly suggest to use a adhesion promoter and plastic primer.
Also I wouldn't worry about the high heat paint. Plain jane automotive paint will work with no problems.
It is all about the prep.
Tecca is offline   Reply With Quote
Old 09-24-2009, 10:45 PM   #3
BumbleDs
BumbleDs's Avatar
Drives: 2010 Camaro RS/SS TF Edition
Oohrah USMC
Love it or hate it, my car can transform and kick your cars @$$!
BumbleDs is offline   Reply With Quote
Old 09-25-2009, 07:29 AM   #4
VenomZ302
Live to Win, Dare to Fail
VenomZ302's Avatar
Drives: 2010 Aqua Blue RS/SS M6
Thanks for the write up and pictures! I'm looking into doing something similar with my engine cover, but kind of reversed. I'll post pictures if/when I get it done.
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6!
7/13/09 - Built!
8/11/09 - Delivered!
2G1FT1EW2A9124579
VenomZ302 is offline   Reply With Quote
Old 09-25-2009, 08:43 AM   #5
vuduman67
Drives: Victory Red 2SS/RS
You are 100% correct on the adhesion promoter and primer on bare plastic but the areas he painted are already painted silver from the factory so really it not needed there as long as its sanded.
My bad except for the V8 section
vuduman67 is offline   Reply With Quote
Old 09-25-2009, 11:15 AM   #6
sav1
sav1's Avatar
now you guys got my scared about my v8 section.. hope it holds up. if not, I'll just knock off the rest of the red and keep it black. We'll see.
Old 12-02-2009, 12:29 AM   #7
kismyss
Drives: CGM 2SS Roto-Fab CAI, Mach XL CAT
Inspiration From Camaro5Forum
Name:  Todd's Camaro 006.jpg
Name:  Todd's Camaro 004.jpg
That was a great write up you inspired me to do the same check this out.
Then i got crazy with the cheez whiz
Name:  Todd's Camaro 005.jpg
Name:  Todd's Camaro 007.jpg
kismyss is offline   Reply With Quote
Old 12-02-2009, 03:27 AM   #8
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
lookin good guys. I like it.
I may want to try it. But, I'll use glossy paint
UCI CamaroFan is offline   Reply With Quote
Old 12-02-2009, 06:27 AM   #9
garcmol
garcmol's Avatar
Drives: 10 1LT SIM; 91 B4C sleeper Z
$380 for an engine cover OR DIY???? I think I will go this route.
But a quick question. I have a V6 and the engine cover will flex coming off of the engine. Does the Duplicolor Engine Enamel allow for flex?
Pedders Pace Car Package, Injen CAI, Flowmaster AT, AAC Lighting, ZL1 fascia/skirts, RKSport Ram Air hood, vented fenders, painted stripes (Gary's Customz), Honor and Valor badged (Thank you, John)
garcmol is offline   Reply With Quote
Old 12-07-2009, 09:23 PM   #10
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
That red looks nice...
It would possibly look nice with some more color on some other areas like the elec cover or air cover...if they are staying...nice job.
I too have heard of the high adhesive plastic Krylon paint on another C5 thread.
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 12-07-2009, 10:06 PM   #11
sav1
sav1's Avatar
Since that paint , I've wet sanded and added 3 more coats of Clear.. it looks 3 times more shinny. Engine cover will flex, and this Dupli color is supposed to be ok for a little flexing.
"What Do I Feel When I Kill A Terrorist? A Little Recoil"
Old 12-08-2009, 03:54 PM   #12
garcmol
garcmol's Avatar
Cool, thanks. I just don't want to paint it, pull it off and have to start over!
Old 12-26-2009, 07:18 PM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Idid mine also and thuoght iit came out ok.Name:  decepticon motor.jpg
chevy 3 is offline   Reply With Quote
Old 01-13-2010, 09:18 AM   #14
tightchevelle69
Derrick
tightchevelle69's Avatar
Drives: 2010 Camaro 2ss/rs
very good write up! i painted mine as well a couple weeks ago because i wanted ABM and, of course, gm doesnt make one with that color. i used actual automotive base coat/clear coat from sherwin williams. it matches beautifully! ill post up some pictures this evening when i get home from work.
one piece of advice i can give on this is if you are using base/clear...BE CAREFUL around the oil cap recess. trying to get clear down in there is a little difficult. i ended up with a nice run on the side of the cover next to that area that i had to sand out!
2010 ABM 2SS/RS, A6, home Dec 10th, wifes birthday present!
2007 GMC Yukon XL, 2000 S10 Xtreme, 1969 Chevelle
tightchevelle69 is offline   Reply With Quote
Camaro Z28 (HP Edition) FACTS: radz28 Camaro ZL1 Forum - ZL1 Specific Topics 44 01-29-2011 10:05 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 09:05 PM
My custom painted engine cover brooks35 Cosmetics and Lighting Modification Discussions 10 09-22-2009 06:33 PM
Engine cover MOD d69chris Cosmetics and Lighting Modification Discussions 33 09-16-2009 10:02 AM
DIY painting your engine cover RoyalKev Camaro DIY & HOW-TO instructions & discussions 8 08-15-2009 01:12 PM
