02-14-2018, 07:16 PM | #1 |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
Smoked Taillight Gap Issue
I recently installed the GM smoked taillights. After installing them, I noticed large gaps (.125") between the light housing and the body on the outward sides (pic 1).
After doing some sleuthing in tight sight lines, it would seem that the two outer body holes where the housing connects to the car are not flush to the housing (pics 2-4). The housing is not held in to the outer holes with nuts like the other 3 connecting points, instead they are held in with what I call the "orange shits" (pic 5). When removing the old taillight housings, i used a hammer to knock out the part of the housing that the orange shits were holding in place, as I dont have the superhuman strength that Lethal Camaro has in his video to pull them out with his bare hands. I would guess that by hammering them out, I damaged the orange shits (which would happen no matter how they were removed I would think?), making them unable to hold onto the same part of the new taillight housing. I am reordering more of the orange shits, and hope that will take care of the problem. In the meantime, did anybody else run into a similar issue with their smoked taillight install? Or is this gap normal and I am being overdramatic?
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
02-14-2018, 08:03 PM | #2 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Following ...
02-14-2018, 09:11 PM | #3 |
Drives: 2017 1LE Join Date: Nov 2017
Hey man. Just changed mine. What would I do? Firmly and deliberately attempt to seat tight in the orange pieces. Then tighten carefully the thre screws down.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
02-14-2018, 09:36 PM | #4 |
Drives: 2017 Camaro SS NGM, 2015 Murano Plt Join Date: Apr 2016
I must have been lucky. I had a gap as soon as I installed mine. It was bothering me so pushed in the corner of of it (my left tail) and reduced the gap significantly to even notice now.
02-14-2018, 09:40 PM | #5 |
Right on. Have to seat tight before you bolt back in. Mine went seemingly easier though but think you got it right. Nudge fitment. Snug it up. Tightn down.
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube Last edited by Chris C 1SS 1LE; 02-14-2018 at 09:41 PM. Reason: Clarity |
02-15-2018, 12:15 AM | #6 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
This is pretty normal. I’ve noticed it on every car with the dark tail lights ever since I installed them. I adjusted my gap with some washers between the car’s sheet metal and the light . I looked into it more and it’s the way the car is built. I confirmed this on my car by reinstalling the stock tail lights and the gap was still off. I started paying attention to all Camaros and noticed the uncongruent gap between sides on most (some were close enoughto call a non-issue).
02-15-2018, 06:35 AM | #7 | |
Since the orange shits are removable, my last resort will be to super glue them flush to the housing and reinstall, which will still let the housing be removable.
02-15-2018, 07:18 AM | #8 | |
The washer idea makes sense.
02-16-2018, 04:40 AM | #9 | |
Fit now flush to the little rubber bump on inside of outer lip. Push slowly but firmly to seat then rotate tightening if the three nuts.
02-16-2018, 11:10 AM | #10 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I find this post somewhat amusing. I was just watching to build a super car Camaro edition last night I will have to look back but when I saw the assembler put in the tail light he gave it a pretty good hit with his palm on the outside corner, I would assume to seat it. But I could be wrong.
02-16-2018, 04:03 PM | #11 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Take it out and reinstall. Had this issue on mine and noticed it wasnt seated correctly. Thats what I get for installing in the garage with the doors closed.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
02-17-2018, 04:25 PM | #12 |
Tried reinstalling, still same issue. Tried putting the orange things on the male ends of the light housing, and seeing if I could even get those to clip into the body unsuccessfully. So I figured either a) I'm an idiot and not installing it correctly or b) they were made incorrectly. a) i tried multiple ways to install these, so would like to think I'm not at fault. Which leaves b). So I decided to take out the male ends, and used machine screws and my impact driver, and that reduced the space to the point where its unnoticeable.
02-17-2018, 09:12 PM | #13 |
Looks good to me. Honestly.
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube Last edited by Chris C 1SS 1LE; 02-19-2018 at 08:27 PM. Reason: Spell |
