04-04-2018, 10:02 PM | #337 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
Sent from my SM-G955U using Tapatalk
Bone Stock |
07-13-2018, 07:34 PM | #338 |
Drives: Black on Black 2SS, ground eff Join Date: Jul 2009
Quick questions about tire brands. I was just told that some tires are bigger than others even though the numbers on both are the same (305/30/20 for example). They show me a picture of 305/30R20 Nitto and 285/30/R20 Michelin and the Michelin was pretty much the same size. Is this true? Thanks in advance.
07-13-2018, 09:35 PM | #339 | |
335 30 20 and its a tight fight. i literally have about 3/8" space inside. hope it helps
Bone Stock |
09-24-2018, 12:45 PM | #340 |
Drives: Buick Enclave/Corvette/2010 Camaro Join Date: Aug 2008
Wanting to work even further outside the box with even taller 22s
Hey Gang,
I need some tire fitment help for my 2010 Camaro and custom 3 piece wheels. (and sorry I've been away so long) I want to go taller in the front, and my fitment was already on the obscure end at the time. I’ve always been one to think a little outside the box, and when my 2010 Camaro was new, the idea of running 30 series tires on 22 inch rims was extremely rare. (And even years later, I love these Rims!) To be specific 22 x 9.5 and +35mm offset using 265/30/22 tires (28.26h x 3.13 sidewall) 22 x 11 and + 37mm offset using 315/30 22 tires (29.44h x 3.72 sidewall) Car is NOT lowered Tires were from VREDESTEIN ULTRAC SESSANTA and are no longer available (I went through 2-3 sets in the years I had the car. I chose this set up because I liked 22s, I likes wide, and I wanted the most sidewall I could have to endure the east coast potholes. I have not found this tire combination from any other manufactures (or for reasonable price.) Also, having hit my fair share of potholes , I’ll like to increase the front Sidewalls some to more equal the rears. Goal, don’t give up any width, and don’t give up any sidewall height (ideally add sidewall height to the fronts) Has anyone successfully run a 265/35–22 or a 275/35- 22? (or perhaps even a 285/35-22) on the fronts? If so, what width and offset is ideal. I hit a center medium in a storm that was part submerged, and damaged the drivers sidec 3 piece wheels. COR wheels has them in FL and is rebuilding all of them (probibly have 80k - 100k miles on them), so I may have some latitude in width and offset. Right now I’m eyeballing a set of Atturo AZ850 275/35R22 Front (29.6 Dia x 10.9 w sidewall 3.8 in) Atturo AZ850 315/30R22 Rear (29.7 Dia x 12.3 w sidewall 3.85 in) They are reasonably priced. Like my VREDESTEIN ULTRAC, they are primarily designed for high performance SUVs The rear size should not be an issue it's the size I run now. (though ideally, I'd like to bring them inboard about 1/4 inch) Thoughts? Any suggestions for changing the wheels width or offset before they are rebuilt (they are mostly just saving the centers and am getting all new inner and outer barrels.) Patrick
***56K miles and still going strong*** 2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM Gary Custom Z vented fenders. Vararam ver 2 Last edited by PatrickfromMD; 09-24-2018 at 12:51 PM. Reason: adding specs for proposed tires |
09-29-2018, 12:09 AM | #341 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Will 305/35’s fit on factory rims and not rub?
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
12-13-2018, 10:42 AM | #342 |
Drives: 2015 Camaro SS Join Date: Jul 2016
Want to go to a 10" wide wheel front,
11" wide on rear for a 2015 RSSS with Brembo brakes. Does anyone know what the correct tire size and offsets should be? |
12-13-2018, 11:38 AM | #343 | |
+23 front 20x10 +43 rears 20x11
Bone Stock |
12-13-2018, 11:40 AM | #344 |
i run 335 30 20 in the rear of my car on factory ZL1 20x11 wheels. No rubbing or any issue at all since July 2017
Bone Stock |
12-13-2018, 11:41 AM | #345 |
Drives: '13 SS RS Join Date: Dec 2012
PS. Stock 20” tire size fits well on 10” and 11” rims. Stretched but looks like 1LE stretch, just about perfect stretch.
So if you still have a good set of tires and want to upgrade, I would consider keeping the tires till it’s worn and due for replacement. Sent from my iPhone using Tapatalk
2013 Camaro SS RS
01-07-2019, 03:53 PM | #346 |
Drives: 2010 Camaro 2SS LS3 Join Date: Oct 2018
Proper Offset to put 275s front and 305s rear
I've noted that the stock wheels are 8J x 20 ET 35 (front) and 9J x 20 ET 40 (rear). I'm looking into purchasing 9 x 19 (front) and 10 x 19 (rear) wheels so I can roll with 275's up front and 305's in the rear. However, I'm worried about the offset calculation, as I wish to not have a lot of tire exposed past the walls. Anyone know how to calculate this, and any other input would be appreciated.
TY, Heel2Toe |
02-14-2019, 06:40 AM | #347 |
Drives: 2015 Chevrolet Camaro 1SS Join Date: Jan 2019
Hey all. I just want to reach out to get your opinions on which tire size I should install.
I have a 2015 1SS and am looking to do a square setup so I can rotate the tires as this is my daily driver. I am looking at the MMR M017 20x10 +23 all the way around. I have seen some run 285/35/20's but I'm concerned these are going to have more gap in the wheel well over stock as I am not lowered. I know that tire size (285/35)does not rub anywhere. Anyone know what a good tire size would be using the wheel setup note above (20x10 +23) that would not rub but be nice and wide and fill up some fender well? PS I cannot really drop the car anymore than stock as I already rub the front lip going into or out of my driveway. |
02-14-2019, 09:06 AM | #348 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
Guess Im the dummy here so ...
OEM on 2012 with 20” wheels is: Front: 20x8; offset 35 Rear: 20x9; offset 40 With the diff tire sizes in your table arent there diff offsets due to tire widths? Would love to see, Im thinking of going to square setup of 20” with tbd rim width and tire size.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
03-31-2019, 01:45 AM | #349 |
Drives: 2010 Camaro 2ss yellow with black Join Date: Mar 2017
Confused
Can I use wider wheels without modified fenders and such?2010 2ss
03-31-2019, 01:49 AM | #350 |
How wide can I get without modifying anything else
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
