Old 02-27-2015, 05:01 PM   #1
allmotor
movin' down the motorway
allmotor's Avatar
Drives: Summiit White 2SS/RS/M6
Can't stop thinking about twins....
like the title reads.... I'm in a constant tt 'loop' in my head. Do I invest in tt's or not. I don't need the extra rwhp, but why not add more. Current set up is 417 ci stroker. Whaddya think? Any negative reason(s) to consider? Cost is not one of them.
417 stroker - Florida Speed and Power
allmotor is offline   Reply With Quote
Old 02-27-2015, 05:19 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
What kind of parts are in your motor and what compression
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 02-27-2015, 05:36 PM   #3
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
If cost isn't a factor then there are zero reasons why you shouldn't do it. These cars are completely different with added hp and I mean an extra 200hp makes a completely different animal and SO much more fun to drive. Quit thinking and do it
jrpxxii is offline   Reply With Quote
Old 02-27-2015, 05:38 PM   #4
jrpxxii
jrpxxii's Avatar
Im guessing if he already has a 417 then he has better parts than stock and there are plenty of people boosting the stock motors with zero issues so this should just add to the fun factor since its already stroked
Old 02-27-2015, 07:25 PM   #5
allmotor
allmotor's Avatar
LRB Performance: http://www.lrbperformance.com/
417 CI
Manley pistons 4cc flat top
Total Seal AP Gold ring set
Compstar rods 6.125
Compstar 4.000 wet sump crankshaft
ARP main stud kit
King Engine Bearings
Latozke Racing Heads: http://www.latozkeracingheads.com/
CNC Stage 3
FSP: http://www.floridaspeedandpower.com/
Cam: 235/247 on a 114+2
Old 02-27-2015, 07:27 PM   #6
allmotor
allmotor's Avatar
Not sure about the compression, but I'll certainly find out. Just don't remember.
Old 02-27-2015, 07:34 PM   #7
allmotor
allmotor's Avatar
Supporting mods: SUSPENSION: DSS axles, BMR adjustable toe links, Pfadt rear trailing arms, Energy Suspension subframe bushings, Eibach Pro-Kit Lowering Springs
DRIVETRAIN: LPE 3:91 gears
ENGINE Misc: C5R Timing Chain, LS2 Chain Damper, Melling High Volume Oil Pump, TSP underdrive pulley
INTAKE: FAST LSXR 102mm manifold, Nick Williams 102 MM throttle body, Cold Air Inductions
EXHAUST: Kooks Long Tube Headers 1 7/8"x 3" with cats and coated
Old 02-27-2015, 08:17 PM   #8
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
Lose the cats. Go with agp and squash return style. Choose injectors and clutch, and if you have the cash a zl1 or gforce rear diff.
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned
z3R0fo01 is offline   Reply With Quote
Old 02-27-2015, 08:23 PM   #9
allmotor
allmotor's Avatar
Appreciate the input.
Old 02-27-2015, 08:46 PM   #10
4510
Drives: 2013 2SS/RS Rally Yellow
417 CI
Compstar rods 6.125
ARP main stud kit
CNC Stage 3
What horsepower are you getting out of your current setup?
2013 Camaro 2SS/RS-6spd- Rally Yellow / AGP Twin Turbo
2015 Challenger Hellcat-6spd- Sublime
I think I see a trend here....
4510 is offline   Reply With Quote
Old 02-27-2015, 08:46 PM   #11
AGP Turbo
Drives: All things Turbocharged
It's really like you've wasted all that money into your engine if you don't take advantage of it's potential. Ya know It wants to make 1000hp for you but is only making half that. You're engine is probably depressed and can't even work up the courage to talk to girls.
Just do it!
AGP Turbo is offline   Reply With Quote
Old 02-27-2015, 08:47 PM   #12
Unreal
Drives: 2006 Z06
Swap stock intake/tb back, sell fast 102/102, cai, and headers. Pays for 1/3 or more of the turbo kit. Slap twins on, do a fore fuel system, enjoy 1000rwhp.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 02-28-2015, 03:34 AM   #13
allmotor
allmotor's Avatar
531 to the wheels
Old 02-28-2015, 11:27 AM   #14
z3R0fo01
z3R0fo01's Avatar
I had a long day yesterday. I think the cats have to go anyway on the agp kit.
Def check out the squash. Even if I didn't have on on my dinning room table I would recommend it. You get exactly what you pay for. It costs a lot but it is the best. Of course in my setup it is overkill, but I am always hearing people say they are losing fuel pressure or that on really long pulls there is a chance of leaning out.
JRE tuned
