Old 12-22-2014, 11:42 AM   #1
ozzycamaross
Drives: camaro SS 2010
LS3 418 Stroker,Nightfury cam GM CNC LS3 Heads
Hi,i Recently Upgrade my Engine with a LS3 thompson 418 LS3 block, with GM CNC LS3 ,Night fury cam,and Fast 102mm intake With Full Exhaust,.do you think i can Reach 550 RWHP with this configuration?i expect to get minium 500-500 RWHP on my ls3 M6 camaro.
thanks for your help.
ozzycamaross is offline   Reply With Quote
Old 12-22-2014, 12:31 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Why Thompson?
Hope it goes well let us know what you make....
62nalide is offline   Reply With Quote
Old 12-22-2014, 08:09 PM   #3
ozzycamaross
Originally Posted by 62nalide View Post
Why Thompson?
hi,thompson is a good guy ,i have experiences in LSx ,the car feels great ,but i dont know if my heads and cam are good to reach the 550 RWHP mark.
thanks!
Old 12-22-2014, 09:13 PM   #4
1989GTA
Drives: 1989 GTA Trans Am
I think the camshaft is to small for 550rwhp.
1989GTA is offline   Reply With Quote
Old 12-22-2014, 09:49 PM   #5
ozzycamaross
in the past i saw a post that someone with LG CAM put 550 rwhp ,i think the nightfury and LG are very simir in the specs.by the way my compression is 11:8:1
thanks!
Old 12-23-2014, 08:39 AM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
thanks!
Seems like you got it figured out.
Let us know how it turned out.
Old 12-24-2014, 07:17 PM   #7
ozzycamaross
I have an idea,and my butt dyno tells me im about at 500 hp,i put this to see if someone with similar setup like me is over 500 hp thanks for your help
Old 12-25-2014, 01:44 PM   #8
allmotor
movin' down the motorway
allmotor's Avatar
Drives: Summiit White 2SS/RS/M6
With this build I'm at 531 rw / 519 tq
LRB Performance: http://www.lrbperformance.com/
417 CI
Manley pistons 4cc flat top
Total Seal AP Gold ring set
Compstar rods 6.125
Compstar 4.000 wet sump crankshaft
ARP main stud kit
King Engine Bearings
Latozke Racing Heads: http://www.latozkeracingheads.com/
CNC Stage 3
Cam: 235/247 on a 114+2
Installed by Florida Speed and Power
Tuned by Slowhawk Performance
417 stroker - Florida Speed and Power
allmotor is offline   Reply With Quote
Old 12-25-2014, 03:37 PM   #9
62nalide
62nalide's Avatar
Drives: 2013 SS
417 CI
Compstar rods 6.125
ARP main stud kit
CNC Stage 3
Thought you made 564rwhp 533rwtq?
Old 12-25-2014, 08:47 PM   #10
allmotor
allmotor's Avatar
That's what I was told but never saw a Dyno sheet. I had it retuned at Slowhawk and I was there for the tune this time.
Old 12-27-2014, 12:46 AM   #11
ozzycamaross
417 CI
Compstar rods 6.125
ARP main stud kit
CNC Stage 3
wow that's good numbers ,I will be happy with that numbers,but I don't know if my heads are not enough for 530hp,.
what intake are you using,ls3 or fast,thanks
Old 12-27-2014, 09:06 AM   #12
allmotor
allmotor's Avatar
For air flow I have a FAST intake with a ported Nick Williams TB and CAI. I bought the FAST and TB before I decided to stroke the motor. If you plan on installing a FAST, check around to determine if the bang for the buck is worth it. Depending on your build and what you plan to do with the extra HP, the stock intake might suit your needs. Maybe check around and compare the flow rate between a FAST (ported and not) vs. a stock LS 3 intake (ported or not). In hindsight, I wish I did.
Old 12-27-2014, 06:11 PM   #13
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Ok a stock ls3 no fuel upgrade yet mast heads jre rough idle blower cam fast 102 ported tb too 492.3 thru the factory cats. I am trying to justify using my 40& or building a new motor before it gets procharger
Js2fst is offline   Reply With Quote
Old 12-30-2014, 10:08 AM   #14
Jason 98 TA
Drives: Camaro
500rwhp should be no problem at all. guys are making 500rwhp with camshaft & cnc heads. We had a customer make 525rwhp with PRC 260cc heads & a 235/239 TSP camshaft on a stock bottom end!
Jason 98 TA is offline   Reply With Quote
