08-05-2014, 01:19 AM | #1 |
Drives: 2010 Camaro V6 turbo Join Date: Feb 2012
PCV barb drilling location???
Hey guys, quick question where is the PCV barb so I can drill it to correct the opening holes?
Pics would be great if possible thanks! |
08-05-2014, 05:53 AM | #2 |
Drives: 2010 Camaro 2LT Victory Red Join Date: Feb 2011
its in the rear on the passengers side valve cover. just follow the hose. you might have to wiggle it alittle bit but make sure you remvove the connector. Just fyi on my camaro when i drilled the openings bigger i was getting alot of oil sucked into my intake. i went back to non drilled stock barb and no more oil...
08-05-2014, 01:49 PM | #3 | |
08-05-2014, 02:59 PM | #4 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Before you drill, take the barb out and see if it is clogged. If not leave alone. I have now been removing and inspecting at every oil change. So far no clogging. The drilling is allowing too much flow. Bottom line keep it clean.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
08-05-2014, 04:16 PM | #5 |
08-05-2014, 06:43 PM | #6 |
having FUN now 13.66@101
This thread will help you out. All good info on the first page. Drilling and location of PCV.
http://www.camaro5.com/forums/showthread.php?t=258202
08-05-2014, 11:23 PM | #7 | |
08-13-2014, 06:18 PM | #8 |
Is it me or is there a certain way of removing the PVC barb?
08-13-2014, 08:12 PM | #9 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Pull and twist. Just be careful not to crush it if you use a pliers to grab it.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
08-13-2014, 11:48 PM | #10 |
Is it like a lefty lossy type of thing because I pulled pretty hard and I was scared I was going to crush it
08-14-2014, 06:10 AM | #11 |
No, it's not threaded. Just friction - fit into the opening.
08-14-2014, 05:48 PM | #12 |
Drives: 2011 RS Join Date: Apr 2011
AMEN!! I did the drill MOD and got at least 4oz. every 1000 miles in the Catch Can. I bought another one from the dealer, drove a 1500 mile road trip vacation, got back..... NOT EVEN AN OUNCE!!! Don't Do It!!
08-14-2014, 08:06 PM | #13 |
Exactly Eddiefuzz. It messed everything up on mine with the drilled barb. When i took my Vararam filter off to clean it i couldnt believe how much oil was in the base of the Vararam filter housing. I thought i blew something.
08-14-2014, 08:18 PM | #14 |
Maybe you guys drilled it open to large? I opened up mine, and see the same amount of oil before and after doing it being caught in my RX catch can.
