03-31-2016, 07:42 PM | #1 |
Drives: 83 el camaro Join Date: Feb 2011
Custom all steel fender vent
Something I just threw together on an old fender I will be splicing into a damaged fender on my 2010camaro nose el camino project when I update it to a 2016 like look. Vent is inspired by Ferarri 599 gtb vents. Cut out the face of the fender up to 1/4 " from the edge, which is where I'll be splicing it in anyways. Bent a new section with the 2 angle bends & bent soft corners onto the edges before welding it to the face of fender. Then made a 1/8" x 1/9" soft corner for the front edge. Made sample grille. Tacked with mig while holding by hand & completed welds with tig |
04-01-2016, 01:31 PM | #2 |
Drives: 2011 SS Join Date: Nov 2011
bump +1 but keep us updated
04-01-2016, 04:18 PM | #3 |
Drives: C6 Corvette Join Date: Sep 2013
gona start something like this on mine...have an extra set laying around as well.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
04-01-2016, 04:20 PM | #4 |
Reminescent of the late 70s early 80s Z/28 fender vents.
Mid 70s were more like gills.
Orange Krush II
04-01-2016, 06:18 PM | #5 |
This is what I'm replacing. Though similar, think the custom one is a big improvement over the 79' Z-28 add in part. Looks more uniform also.
Figured I'd see if I could inspire someone to make them something. I started with a whole new section to eliminate 2 weld seams since I was splicing near the fender end anyway, but most people would just slit the metal back up to the end of the fender & weld in 2 triangle shapes. |
