Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 08-23-2015, 02:35 PM   #1
whidobie
whidobie's Avatar
Drives: 2011 Camaro Convertible 2SS RS
Schosche install & air conditioning does not work
Has anyone experienced the install of a Schosche and the air conditioning does not work at all?
Suggestions?
whidobie is offline   Reply With Quote
Old 08-29-2015, 01:41 PM   #2
whidobie
whidobie's Avatar
FIXED! Factory settings had it fr the Chevy Malibu. My installer changed it to the camaro in the settings and everything worked correctly!
Old 10-13-2015, 09:00 PM   #3
splashtop9800
Drives: 2013 Rally Yellow Camaro 2LS
Where do you go to find which car the kit has it defaulted to?
splashtop9800 is offline   Reply With Quote
Old 10-18-2015, 07:35 PM   #4
camarostar2010
Drives: 2011 SS
I HAVE HAD THIS ISSUE. iT HAPPENS INTERMITTENTLY. USUALLY IF THE POWER AT THE BATTERY IS LOW...OR IF YOU TURN THE IGNITION TO THE ON POS, THEN OFF, THEN ON AGAIN TOO QUICKLY. SOLUTION "TURN CAR OFF AND REMOVE KEY, WAIT A FEW SECONDS AND TURN CAR ON. IF THAT DOESNT WORK, JUST IGNORE AND IT MIGHT KICK ON AT A LATER TIME...ALL BY ITSELF. SO WHAT I DO IS LEAVE MY FAN SPEED AND WHAT TEMP I USUALLY LIKE ON 1 SETTING. IF YOU DO THIS IT SHOULD KICK ON TO THAT ALL THE TIME BUT YOU MIGHT BE ABLE TO CHANGE IT AT WILL ALL THE TIME. I HOPE THIS HELPS. SCOSCHE HAS SOME ISSUES SOME TIME BUT I STILL LOVE THE KIT.
camarostar2010 is offline   Reply With Quote
