01-04-2024, 11:52 PM | #15 |
Electrical Engineer
As someone who spent a lot of time trying to make that work, it's not easy, even for someone willing to strip an entire car for acoustical treatment and install a $500 pair of 6x9s back there. For one, even if you install the adapter on the top to align screw holes - one of the holes is blocked by the rear deck. And second, the metal itself prohibits direct mounting. One could fabricate a mount for underneath, that effort would likely suck as it won't be flat and has to conform to awkward undulations, and then sacrifice that height in the trunk.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 Last edited by keep_hope_alive; 01-05-2024 at 12:02 AM. |
01-05-2024, 01:08 PM | #16 | |
I was probably thinking of this thread by kingLT1: https://www.camaro6.com/forums/showthread.php?t=510907 |
01-05-2024, 06:06 PM | #17 | |
https://www.camaro6.com/forums/showthread.php?t=601570 Some space is compromised, but not a big deal for most people. |
01-06-2024, 09:58 AM | #18 |
I've gotta look at mounting my amp to the rear deck like that. Would save a little room over having it sitting on the floor.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
03-21-2024, 05:26 AM | #19 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
By using the previously mentioned amp, could you replace the 2 ohm stocks with standard 4 ohm speakers (assuming you could mount them)?
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
04-09-2024, 08:50 PM | #20 |
Drives: 2016 camaro Join Date: Jul 2023
In general the rear speakers are to be for rear fill and not really noticed.
I believe they are difficult to get to as well. There are You Tube videos on upgrading. |
04-10-2024, 12:50 PM | #21 | |
I have done this in my previous car and I cut a hole in what would normally be the bottom plate of the amp and mounted a computer hard drive cooling fan to cool the unit. I think the HDD fans were designed for 5 V. There are typically 2 little fans on the unit, so wire them in series and pull 12V from the amp's switched power. |
04-12-2024, 02:42 PM | #22 |
Drives: 2016 Chevrolet Camaro 2SS Join Date: Feb 2024
Would lc-4.800 work for this situation? To amplify all 4 rear speakers?
