03-07-2016, 02:43 PM | #15 | |
Drives: 1LT Join Date: Mar 2014
I'm sorry! I forgot to mention that I borrowed my friend's stock cats to revert the car back to normal. It was 100% stock. |
03-07-2016, 02:49 PM | #16 |
I completely changed the coil pack for cylinder 2. I bought it from GM. The coil pack can't be the issue. Tell me if I'm wrong, from my understanding, you are suggesting that the wires maybe the cause of the issue.... I never thought of the wires being the issue. I'll give it a shot. Thanks for the help! Cheers
03-10-2016, 09:18 AM | #17 |
Update 03/10/2016
Throttle body was cleaned by GM. The car ran the same way as it did before. I decided to dump in"STP full fuel system cleaner" into my gas tank 100 miles after the cleaning. The car's performance came back! However, at idle, the car is still running rough and the engine is shaking a lot (not as much as before). The car is also running rich. At this point. I know that the problem is related to the fuel system.
I have purchased a new fuel injector for cylinder 2 (misfiring cylinder). Before I switch the old with the new, I'm going to get the injectors cleaned out. |
03-10-2016, 10:10 AM | #18 | |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
03-10-2016, 10:14 AM | #19 | |
03-10-2016, 10:53 AM | #20 |
All the spark plug wires. Since your getting a cylinder misfire I would start at the boots and work your way back to the coils. It should "literally" arc if the wires are close enough to something which I'm guessing they are. Another way to check is to start the motor wet down all the spark plug wires with just water and run a multimeter along with one side grounded out and it will arc to multimeter. I'll bet its arcing off one of the header tubes while running
03-10-2016, 10:55 AM | #21 | |
03-10-2016, 10:59 AM | #22 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
You are correct.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
03-10-2016, 11:05 AM | #23 |
oh damn my bad I thought you had an LS3. If thats the case I'm not really sure how to check those bc they are all in seperate plastic sleeves leading up to the coils correct?
03-10-2016, 11:26 AM | #24 | |
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
03-10-2016, 11:27 AM | #25 |
Yeah my mistake, thought he had the Ls3
03-23-2016, 10:42 AM | #26 |
UPDATE 03/23/2016
Fuel Injector for Cylinder 2 has been replaced. Car is still running rough. Error codes P16A1 and P0300 have appeared on several occasions. I have come to a conclusion. My ECM has failed. I will have it reflashed by GM tomorrow and update everybody on it. If the reflash does not work out, I will probably need a new ECM.
For those of you wondering why the reflash wasn't the first thing I tried doing before chasing parts, the three dealers I went to all refused to reflash my ECM even though I offered to pay. The reason was; "Your car is modified. We do not work on modified cars." I didn't even bother arguing. My local mechanics obviously don't have the tools to reflash the ECM. I finally found a dealer that is willing to do it. |
Tags |
cats, engine, injectors, issues, problems |
