Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-28-2013, 04:09 PM   #1
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Hesitation, Jerking, Bucking At Start-up Only
I have a 2013 ss automatic camaro with less than 1,000 miles on it. Ever since I got the car, I sometimes notice that when I first start the car up and give it some gas, the car hesitates, jerks and bucks. This either happens in drive or in reverse.
However, the hesitation, bucking, jerking, etc. immediately stops once I get going and does not come back. It seems to only happen during the first start-up of the day.
Anyone else have this?
njweatherman is offline   Reply With Quote
Old 06-28-2013, 05:07 PM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
Thats normal on my 2011 ss, been like that form day 1, till it warms up
meshamey is offline   Reply With Quote
Old 06-28-2013, 05:43 PM   #3
njweatherman
Thanks for the input. I was worried something was wrong.
Old 06-28-2013, 07:44 PM   #4
meshamey
Meshamey
meshamey's Avatar
It is possible If the car is that new, im sure dealership put 87 octane gas in it.. that's a big NO NO. have you been putting 91 or 93 octane in it? you may need to do the fuse pull to get the computer out of low octane mode. Just do a search on fuse pull..
Old 06-29-2013, 07:03 AM   #5
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
This is perfectly normal and has nothing to do with the fuel in the car.
The sensors throughout the car do not communicate with the computer control module until a certain temp is reached. As a result, you get the hesitation for the first few minutes of operation.
This is well documented here on the site. Sift around through some of the older posts and you'll find additional info.
TheHorse13 is offline   Reply With Quote
Old 06-30-2013, 01:01 PM   #6
njweatherman
@meshamey - I only use 93 octane and I went with the dealer to the gas station when they filled the car with 93 octane.
@TheHorse13 - good info. I mentioned it to the dealer and they had no idea what was causing it.
Old 07-01-2013, 09:58 AM   #7
jethrobandit
jethrobandit's Avatar
Drives: 2013 Black 2SS
I was searching through the site looking for threads on this issue and glad to find something current. I have this issue on an M6 and figured it was due to it not being warm, but wanted to find out for sure. Have a CAI on it and wondered if new throttle body would improve it, but if its the computer, not much will help that I assume.
jethrobandit is offline   Reply With Quote
Old 07-01-2013, 01:13 PM   #8
TheHorse13
TheHorse13's Avatar
Nothing will improve it. This is how the electronics on the car are designed to work.
Old 07-01-2013, 01:41 PM   #9
suzook
Drives: camaro
Remote start it like I do....only needs a 1min warmup...then all is good!
Hyperblue/JetBlack
Old 07-01-2013, 06:55 PM   #10
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
I put my DIC to coolant temp and wait till 160 F. This seems to keep the engine and me happy.
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 07-01-2013, 08:08 PM   #11
suzook
Drives: camaro
Talking
Your dic at 160??? Ouch!
Hyperblue/JetBlack
Old 07-01-2013, 08:10 PM   #12
Rhyder
Drives: 2012 45 Anniversary Vert
hmmm...I always just crank and go, and I don't believe I have ever experienced this, I have a 2012 Auto, is this a 2013 thing?
Rhyder is offline   Reply With Quote
Old 07-04-2013, 02:23 PM   #13
njweatherman
@jethrobandit - if you decide to get a throttle body, let me know what one you get and if you see an improvement. I'm taking mine to the dealer once I approach 3000 miles so they can test everything.
Old 07-04-2013, 02:27 PM   #14
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
The VMAX throttle body does not do anything for this. I have it as well going in reverse. Only way around it is let it run for about 30-60 seconds.
dixonk is offline   Reply With Quote
