Old 10-04-2023, 10:28 AM   #1
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Oil recommendations
I see alot of posts regarding Oil recommendations. I always run a Mobil1 extended performance filter and Mobil 1 extended performance synthetic 5w-30 motor oil.
Now that my car is supercharged, I am wondering If I should consider changing my oil to something with more viscosity, a different filter to protect the engine better. I know that everyone is gonna say Amsoil, but I would really like something that i can just go to the local Oreilly's and buy if possible, although if Amsoil is the reigning champion I will bite the bullet to protect my baby. Do I need to make a change at all or is what i am running more than adequate? 10psi of boost, centrifugal supercharger, making 530rwhp.
Thanks everyone!
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 10-04-2023, 10:34 AM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
No reason to change what you are using in my opinion. You didn't do any block work right?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 10-04-2023, 10:41 AM   #3
Anthony S
No, stock internals LS3. 45,000 miles if that matters.
Old 10-04-2023, 01:18 PM   #4
SS_Dave
SS_Dave's Avatar
Drives: Chevrolet Camaro SS
No point to change brand or weight. Just keep it changed regular.
And yeah, I use Amsoil. But I doubt any diff so long as you keep it changed regular.
SS_Dave is offline   Reply With Quote
Old 10-04-2023, 02:25 PM   #5
ChibiBlackSheep
Then keep with what you've done.
Old 10-04-2023, 02:52 PM   #6
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
I've always thought it was more important to change the oil frequently rather than
what brand you select. I did my 20th oil change after 14+ years and 72,000 miles
on my '10 SS. Never one engine sound or problem on my stock L99. Just IMO.
myold88 is offline   Reply With Quote
Old 10-04-2023, 09:43 PM   #7
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I think that the Mobile 1 5W30 is good enough since your still at such a low mileage and still stock internals. I only changed mine because I did a full rebuild on mine with forged internals and cam.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-04-2023, 10:26 PM   #8
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I don't feel like wading in the brand name arguement waters today. I don't know if it makes so much difference on a street car if it's changed occasionally.
I go with ?W40 nowdays. I know before the thinking was ?W30 but I believe that's changed.
silversleeper is offline   Reply With Quote
Old 10-05-2023, 05:35 AM   #9
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Did you also switch to E-85 as well? When I went S/C & E85 the oil temps were pretty high in the summer with Mobil 1. I first switched to Driven GP1 15w40 and that helped a little bit. After talking with Driven reps I tried their LS30 oil (5w30) and it dropped the oil temps back into normal range. I ran that until I pulled the engine over the winter. The Driven LS30 oil is crazy expensive now though!
Thankfully with the new engine they have me using Driven GP1 20w50 which is not as expensive and works well. Its a greenish color oil and is a bit freaky to see when you first pour it out of the bottle.. lol
If I am just driving it around I might go a month or two on an oil change but if it goes to the track I change it afterwards regardless of when it was changed last.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 10-05-2023, 06:42 AM   #10
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
If heavily modified, and/or clearances have changed, then use the builder's or parts manufacturer's recommended oil. It could even be a warranty thing to use a certain type of oil.
If mostly stock clearances and internals, I'd go with a QUALITY oil, standard weight, with a good filter, and do regular oil changes/maintenance. Pick your brand. I've never seen or heard of an engine dying simply because they used Mobil 1, Amsoil, etc. They usually died because something came loose or clearances weren't right, parts break, other issues...
Just my personal choice- I stick with Mobil 1 becasue it's available nearly everywhere. Never had an issue on any of my stock LS type Camaro engines using Mobil 1. I also use either the ACDelco UPF filter or Mobil 1 equivalent filter.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 10-05-2023, 08:08 AM   #11
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I'm an Amsoil fan. But as often as I change oil, I could probably run Mazzola oil!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is online now   Reply With Quote
Old 10-05-2023, 08:17 AM   #12
Anthony S
NO still pump gas 93. I assume that my traditional oil change will suffice. I think I may need to consider making a change once I perform a cam and valvetrain upgrade. I'll just keep an eye on Oil pressure and oil temps and if something starts to show its face, ill look into other options.
Old 10-05-2023, 10:34 AM   #13
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Consider doing a Blackstone analysis. Good peace of mind for $40.
ariZona28 is offline   Reply With Quote
Old 10-05-2023, 10:52 AM   #14
Anthony S
I actually have a kit sitting in my garage... Might take a sample from my first oil change.
