Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-19-2013, 12:27 PM   #1
Flea
Drives: Camaro ZL1
Fuse pull & Check Engine light
Did the fuse pull about week ago, and I just wound up having the check engine light come. OnStar ran a diagnostic on the car, and the lady told me the exhaust emissions system isn't functioning properly and I can have the maintenance done at my leisure. I'm not positive the fuse pull caused this, but I'm suspecting it is. I did just fill up the car last night and have driven about 100 miles on the the tank. So it's possible it could be bad gas. Has anyone else had the fuse pull cause the check engine light to come on? Just wondering, before I go put the fuse back in.
Flea is offline   Reply With Quote
Old 05-19-2013, 12:57 PM   #2
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
My fuse has been out for 3500 miles, with rotofab CAI, no tune and no light. I doubt its the fuse that caused it.
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 05-19-2013, 02:06 PM   #3
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Depends on the code thrown. I also want to know which fuse did you pull? The F8 fuse in the trunk for the exhaust?
ZL1-V is offline   Reply With Quote
Old 05-19-2013, 03:04 PM   #4
Flea
Drives: Camaro ZL1
Sorry, guys. Yeah, it was the F8 exhaust fuse I pulled. I should've mentioned that.
Since OnStar said it wasn't a big deal, I'll run this gas out and see if the light goes off. Won't take too long to do that. lol If it doesn't go off, I'll stick the fuse back in and see if that solves it. After a week of that nice sound with the flaps open, it would suck to have to go back to stock. I would definitely have to go the route of the Mild 2 Wild controller.
Old 05-19-2013, 03:12 PM   #5
2012-1822
2012-1822's Avatar
Drives: Black ZL1
I pulled mine at the first of May or so and no issues
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 05-19-2013, 04:51 PM   #6
Buka
Buka's Avatar
Drives: 2013 ZL1 Black
Gas cap back on correctly after filling up?
Buka is offline   Reply With Quote
Old 05-19-2013, 05:07 PM   #7
Flea
Drives: Camaro ZL1
Yeah, it was. I even double checked it when I noticed the light was on.
Old 05-19-2013, 06:11 PM   #8
rzrbck_zl1
rzrbck_zl1's Avatar
Drives: '13 ZL1 CRT #702; '05 Hemi Ram
Pulled the F8 fuse months ago, and have had no issues.
rzrbck_zl1 is offline   Reply With Quote
Old 05-21-2013, 05:26 PM   #9
Flea
Drives: Camaro ZL1
Noticed this morning that the check engine light is off now. Must've just been some bad gas. I didn't even run the whole tank out. My guess is that it had some bad gas in it, and then the better gas that got mixed in got rid of the problem.
Old 05-21-2013, 05:28 PM   #10
ZL1-V
ZL1-V's Avatar
Or a failing O2 sensor?
Old 05-21-2013, 05:46 PM   #11
Flea
Drives: Camaro ZL1
I guess that's a possibility also. I'll be keeping an eye on it, to see if the light comes on again. If so, I'll stick the fuse back in and take it to the dealer, so they can check everything out.
Old 05-21-2013, 05:50 PM   #12
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I wouldn't think the fuse pull would do that, the fuse I believe is only to open the second valve for the exhaust.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 05-21-2013, 06:08 PM   #13
Flea
Drives: Camaro ZL1
Right. I understand that. I just figured putting the fuse back in would ensure that everything was just as stock, so if there was an issue, there would be no question as to what it was.
Old 05-21-2013, 06:25 PM   #14
Sven59
HAMMER PILOT
Sven59's Avatar
I understand that, I do believe the valve runs off vacumm. Maybe a slight chance it affected the vacumm causing the light?
