08-02-2015, 08:53 PM | #1 |
Drives: 2016 C7, 2016 370Z, Future 1LE Join Date: Jun 2015
Skip Shift Eliminator Question
I plan on getting a manual transmission and have a question for anyone experienced with a skip shift eliminator. Will installing this void the warranty if a problem with the transmission arises?
08-02-2015, 08:54 PM | #2 |
Drives: 2007 Corvette Z51 Join Date: Jul 2015
Usually, it would be removable and undetectable in case of a warranty need.
08-02-2015, 10:25 PM | #3 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
08-02-2015, 11:56 PM | #4 |
Drives: vrod muscle Join Date: Apr 2015
It only makes you skip 1-4, correct? Meaning if you start in 2 for casual driving it won't be an issue anyway?
08-02-2015, 11:58 PM | #5 |
08-03-2015, 01:09 AM | #6 |
Drives: camaros in his dreams Join Date: Jul 2015
I asked someone about the trany(he had zl1)and said it has short throws.but i didn'f have much time to ask him my other questions.
1.how is the clutch pedal? 2.is it light or stiff? 3.anoying in traffic? 4.did you ever had problems with getting the shifter into gear? 5.do you get the short throw gears in the ss too? I will apreciate it if you or anyone who experianced the stick in camaro answer them.thank you |
08-03-2015, 10:15 AM | #7 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
It won't affect your warranty, but if you're worried what the dealer will say if you have a transmission problem you can remove it as easily as you can install it. It's a simple plug connection.
08-03-2015, 11:47 AM | #8 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
I've never had or seen an issue with the skip shift eliminator.
08-03-2015, 09:46 PM | #9 |
Drives: 2016 Camaro Join Date: Jan 2014
Is it in the V6 manual? Had a 2010LS and now 2014LT both manual and never noticed it... hmm
Posted from my BlackBerry Passport |
08-04-2015, 09:50 AM | #10 |
The V8 manual has it to get around the gas guzzler tax, not needed on the V6!
08-04-2015, 10:03 AM | #11 | |
08-04-2015, 02:09 PM | #12 | |
Drives: TBD Join Date: Aug 2013
Sounds like a skip shift eliminator is the way to go - check out this MT rant in their long term Z28 update.
Given the software changes made to the tranny to add the rev-matching I'd be cautious about using any existing solution until it's been thoroughly tested with the new car. Last edited by DevonK; 08-04-2015 at 02:21 PM. |
08-04-2015, 04:30 PM | #13 | |
08-04-2015, 04:40 PM | #14 |
CamaroFan63
Drives: '15 1LT Summit White Join Date: Jun 2015
People have even had the dealership install the skip shift for them.
