Old 05-11-2015, 07:41 AM   #15
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Thumbs down
I'm glad to see the emphasis on aerodynamics but still with the oversized front bowtie? Come on GM!
DrkPhx is offline   Reply With Quote
Old 05-11-2015, 07:42 AM   #16
HuJass
Drives: GM
Originally Posted by GM-ACE View Post
5th gen refresh. Disappointing.
All the improvements are great, but their lack of cojones to actually step forward with a fresh design is just flat disappointing.
Do you have an idea of how you would have liked the car to look?
Can you point to another car as an example?
What would you like to have seen in the new car?
Genuine, sincere questions.
2015 Camaro 1LE
2009 Challenger R/T
2007 Solstice GXP
2004 Colorado ZQ8
2002 Trans Am WS6 Collector Edition
1999 Blazer
1994 Grand Prix SE B4U
HuJass is offline   Reply With Quote
Old 05-11-2015, 07:44 AM   #17
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
GM isn't exactly on financially solid ground. I can completely understand them not wanting to completely toss out the gen 5 design that was so wildly popular. Remember the gen 4 Camaro? They went out on a limb there and it killed the brand.
Thor142 is offline   Reply With Quote
Old 05-11-2015, 07:46 AM   #18
velocity149
velocity149's Avatar
Drives: 2014 2SS RS LS3
The profile shot was included in the Invitation email for us going to Belle Isle.
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS
velocity149 is offline   Reply With Quote
Old 05-11-2015, 07:50 AM   #19
Denis
Denis's Avatar
Drives: 2010 SS
looks like a perfect candidate for a flowtie
Denis is offline   Reply With Quote
Old 05-11-2015, 07:55 AM   #20
MrChrisLS3
Drives: 2018 1SS M6
“The importance of aerodynamics increases exponentially as we increase vehicle performance,” said Kirk Bennion, Exterior Design manager. “As engine output increases, we need more engine cooling. As acceleration and top speeds climb, we need to reduce lift for better high-speed stability. However, we cannot make any changes at the expense of increasing drag, which can hurt fuel economy.
So, what I read in this is that, yes, the SS will have the 455 HP LT1. Also that the ecu top speed limiter of 155 may be removed.
I think the roof line looks good.
MrChrisLS3 is offline   Reply With Quote
Old 05-11-2015, 07:57 AM   #21
Denis
Denis's Avatar
Drives: 2010 SS
maybe not removed, but sounds like it may be raised.
Old 05-11-2015, 08:00 AM   #22
KMPrenger
KMPrenger's Avatar
Yep...not much to see here....other than that HUGE mouth the front end is going to get. I'm sure when we see the entire front end it will balance out more, but just by looking at that one picture alone, the lower opening looks ridiculously large. Hope once it all comes together it will look good. There are a few lines in the profile shot that are pretty cool that aren't in Chaz's rendering. Such as the line that runs from A piller all the way back, over the side windows to the back. Also, the line that wraps under the rear 1/4 glass and goes all the way to the front fenders.
Assuming the bowtie is the same size as the 5th gen, this shot seems to show that the top opening is even slimmer than the 2014-2015 Camaro front end, which already seems pretty tight. On the newer 5th gens, there is still a bit of grill gap above and below the bowtie. On this 2016, it looks like there is very little gap at all.
I was hoping for a little bit more than this, but oh wells...5 days folks!!!!!!!!!!!!
EDIT: N/m...Chaz is on the ball like usual and has updated his rendering to match the new lines....http://www.camaro6.com/forums/showpo...&postcount=825
Old 05-11-2015, 08:02 AM   #23
KMPrenger
KMPrenger's Avatar
Yes it will have the LT1 (already confirmed) but we have no clue exactly how much power it will throw down.
Also, bet on the limited not being removed. Raised? Maybe. But these limiters are used in conjunction with the tire's speed rating...not the capability of the vehicle as a whole.
Old 05-11-2015, 08:06 AM   #24
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
For example, the initial design called for the lower grille bars to be set at a 20-degree angle to the horizon. However, after meticulous testing, the team improved engine-cooling airflow by 1 percent by shifting the angle to 13 degrees – a change that achieved the airflow target while maintaining the original grille design.
Part of me is a little bit disappointed that they took this approach. I miss the wider grill opening that existed before the mid-cycle refresh in 2014.
RenegadeXR is offline   Reply With Quote
Old 05-11-2015, 08:09 AM   #25
KMPrenger
KMPrenger's Avatar
I'm OK with the bowtie. But I think that's partly b/c I now one of the first things I'm going to do is either replace it with some sort of "flowtie" thing or just do what I did on my 5th gen and put carbon fiber imitation wrap on the inside of the bowtie, while leaving the chrome portion visible. Makes for a very nice change to the car.
Old 05-11-2015, 08:10 AM   #26
mako22
mako22's Avatar
Drives: 2017 HB 2SS
lightened....
mako22 is offline   Reply With Quote
Old 05-11-2015, 08:11 AM   #27
mako22
mako22's Avatar
Drives: 2017 HB 2SS
better view
Old 05-11-2015, 08:13 AM   #28
GM-ACE
Old school tech
GM-ACE's Avatar
Drives: Ruby 1LE - 2024 2SS 1LE
Looking at the design changes from the 1st through 3rd gens, there is substantial change in style that is obvious. For better or worse? That's debatable, but the designs weren't stale, they were considered cutting edge. Especially the 3rd gen.
That's what I wanted, cutting edge with a minimal influence from the previous gen, but not this much. It won't set itself apart enough, looks - wise
The other thing that's bothering me is the way GM keeps following Ford's designs. Ford comes out with a retro mustang, GM resurrects the camaro with a retro. Have you looked at the latest mustang? Tall A pillar - fastback C pillar and the edges of the tail light section are very similar in how it helps to form the trunk lid overlap.
In short, there is nothing original in this new gen's looks, just tweaks from the last model.
Say what you will about Ford, but the one thing they are not doing, is resting on their success. Don't get me wrong, I won't own a Ford, but I do admire the way they push the design envelop.
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51
Ordered 2024 Radiant Red 2SS 1LE
Ordered: 6/15/23 Accepted: 7/5/23
3000 - 7/5 ---> 3100 - 7/19
3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7
4300 - 8/14 --->4B00 - 9/5
DELIVERED 9/20!!
GM-ACE is offline   Reply With Quote
