Old 04-29-2023, 10:15 AM   #1
FLGator75
Don't Tread on me!
FLGator75's Avatar
Drives: 2017 Yellow Camaro RS/V-6.
Send a message via ICQ to FLGator75 Send a message via AIM to FLGator75 Send a message via Yahoo to FLGator75
Unhappy Code P06DA
This code popped up on my code reader after the "Check Engine" light came on.
What could the problem be?
Thanks for any advice.
FLGator75 is offline   Reply With Quote
Old 04-30-2023, 08:17 AM   #2
Hadies
Hadies's Avatar
Drives: 2017 Camaro 1LT
This is a fault with the oil pressure control solenoid valve. I wouldn't drive the car until you confirm proper oil pressures, I will grab the troubleshooting steps from the service manuel and post them in a moment.
Hadies is offline   Reply With Quote
Old 04-30-2023, 09:19 AM   #3
Hadies
Hadies's Avatar
On our engines this is part of the oil pump, if its just the solenoid it can be replaced independently of the pump here is a video i found of its location
I have attached the troubleshooting section for this code and the wiring diagram, i hope these help
