01-04-2017, 05:59 PM | #43 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Thanks! Some others that have ordered are still waiting for theirs, the post office tracking doesnt seem to be working, we are calling in the morning to try to track those down.
01-05-2017, 09:12 AM | #44 |
01-10-2017, 08:55 AM | #45 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Ordered! I'll post up my results
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-10-2017, 11:06 AM | #46 |
Thanks for the order, they are going pretty quick! I have had several local guys come by to try the shifter in my car and they can't believe it's the OEM style.
01-13-2017, 07:12 PM | #47 |
Install Pics
Out with the old.
Orange Krush II
01-13-2017, 07:14 PM | #48 |
Install Pics
In with the new.
Orange Krush II
01-13-2017, 08:23 PM | #49 |
01-13-2017, 08:44 PM | #50 |
I removed the exhaust and drive shaft for replacement parts, so the base was right there and it was 2 10mm nuts and it came right off, now the new one I put a little bit of grease and used a soft face mallet and tapped into place reinstalled the 2 10mm nuts easy peasy lemon squeezy!!! I hope to drive tomorrow afternoon Sunday morning and will report back then Monday at the latest.
Orange Krush II
01-13-2017, 08:52 PM | #51 | |
01-13-2017, 11:35 PM | #52 | |
Shifter
Shouldn't have to but also depends how you go after it. I was changing exhaust and DS and bam it was there.
Orange Krush II
01-14-2017, 06:25 AM | #53 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
Put mine in yesterday, 30min tops, all i had to do is slide the heat shield back to get access. Suggest grease shifter tabs to assist with unit sliding on, then bolt all back. Made alot of difference IMO.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
01-14-2017, 08:16 AM | #54 |
Did you have to drop the shifter base including disconnecting the shifter lever from the linkage rod to get to the bushing housing? How ez is it to get the eom bushing housing off the shifter base?
01-14-2017, 02:31 PM | #55 |
Got mine installed, probably 45 minutes. Huge difference in shift feel. The stock bushing looked pretty bad in mine
2010 2SS/RS
01-14-2017, 02:39 PM | #56 |
I have been able to do it without dropping anything, but I have all kinds of wiggle sockets and extensions.
Thanks for the positive feedback everyone! Our goal was near full shifter replacement feel for a lot less cost, I think we achieved it! |
