03-29-2011, 08:45 PM | #99 |
Camaro Obsessed
Drives: 2010 ABM 2SS/RS Supercharged A6 Join Date: Mar 2011
Not that old, and I am new.
Riki driving SSafire, a New-to-Me 2010 2SS/RS A6 ABM w/Ghost Rally Stripes
Mods done before I got her: Vortech V3 Supercharger, full exhaust, high flow cats, LTH, trailing arms, tow rods and anti-sway bars, window tint, body kit - I've since added Drag Radials Mods Up Next: Linelock, upgraded air filter, heat shield Dyno 601 RWHP 8/20/2019 - Purchased from fellow CCOTR member, who purchased from another CCOTR member in 2015 Gone to a new home: Nadia-2014 2SS/RS A6 IBM Gone to a new home: Eva-2011 2LT/RS M6 IBM Supercharged! |
05-31-2011, 03:48 AM | #100 | |
Drives: Orange 2011 Convertible Camaro Join Date: May 2011
06-05-2011, 06:33 PM | #101 |
Drives: Civic 09 lX-s Join Date: Jun 2011
i think law 19 needs to be replaced with...
If a Camaro is to race another camaro, at the end of the race they're both to be declared winners. A camaro is simply too great to lose.
06-06-2011, 09:50 PM | #102 |
357FRED
Drives: 69 protouring camaro Join Date: Jul 2010
i like #10
FRED
06-06-2011, 10:34 PM | #103 |
Older than I look....
Drives: 2010 VR Camaro 2SS/RS LS3 Join Date: Feb 2011
Isn't the Camaro the REASON that XM radio has the Hair Nation station???
High Heels and Fast Wheels!!
11-09-2016, 02:25 PM | #104 |
Drives: Miss Con Ception Join Date: Aug 2016
I was searching for the "Things You Don't Know About your Camaro" thread and that failed, but this came up.
So I thought I would revive it just so we can see Ladybugsmom's avatar. What I wanted to add to the "Things You Don't Know About your Camaro" was that the backup lights in an LS3 don't come on unless the engine is running. That's right. Sticking it in R and turning on the key doesn't do it. I discovered this a few months ago when I had my right shoulder replaced. I no longer could turn around in the driver's seat and look out the back window so I added a backup camera. I searched this forum and found the wires that powered the reverse lights, or so I thought, but there was no power until the car was running and in reverse. Which meant I needed a helper to hold in the clutch. Then I had to trust him with my life. With an automatic you can set the parking brake and chock the wheels, but we all know what is going to happen when the clutch comes out on an LS3 in reverse; you will be a spec on the wall if you are behind that bad boy.
2011 1SS/RS LS3 CGM
11-09-2016, 03:15 PM | #105 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
this one?
http://www.camaro5.com/forums/showthread.php?t=107447 or? http://www.camaro5.com/forums/showthread.php?t=412425 or? http://www.camaro5.com/forums/showthread.php?t=23767
11-09-2016, 04:43 PM | #106 | |
So that is worth the necro
2011 1SS/RS LS3 CGM
11-09-2016, 05:38 PM | #107 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
11-09-2016, 05:40 PM | #108 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
Hybrid Camaro, new fuel economy rules = way higher price? | Cubanaso | 5th Gen Camaro SS LS LT General Discussions | 112 | 10-20-2009 10:21 PM |
Camaro (concept) Press Release!! | Pencil.Fight | 5th Gen Camaro SS LS LT General Discussions | 4 | 07-21-2008 03:33 PM |
