02-26-2014, 08:06 PM | #1 |
Drives: 2015 CRT 2SS/RS 1LE Join Date: Feb 2014
Install MRT V2 without Jack's?
Do you think I could manage installing the MRT V2 exhaust with the car just sitting on garage floor, no jacks or lift? I think I'd have enough room but want to confirm....
Thanks! |
02-26-2014, 08:23 PM | #2 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Sounds tough to me
02-26-2014, 08:32 PM | #3 |
Not enough ground clearance?
I couldn't lay on my back and cut it off 3" from muffler? |
02-26-2014, 08:32 PM | #4 |
Just get a pair of cheap jack stands, they will make the job possible and easier.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
02-26-2014, 08:46 PM | #5 |
Didn't realize I could get some for $25. Looks like I'll need to make sure they have good welds though...
02-26-2014, 08:47 PM | #6 |
When I had my '12 LT, I laid a couple of 2x6s down with a brick under one end and drove the rear wheels up on it. Even then it was difficult since I used a full-size sawsall to cut the pipes. Got it done though.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
02-26-2014, 08:54 PM | #7 |
Can I rent a sawsall somewhere probably? I know I'd have to check my area but generically is that a common rental tool?
02-26-2014, 09:03 PM | #8 |
Yes. Any good place that rents tools will have one. Probably $15-$20 a day. You can cut the pipes with a typical hand-held hack saw. There's very little clearance around those pipes. Be sure to get the long metal cutting blades for the sawsall.
02-26-2014, 09:07 PM | #9 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
To quote Jeremy Clarkson from Top Gear UK "Even the smallest of chaps with the whitest of teeth could not manage that one"
On a more serious note I highly doubt it can be done without some form of raising the car. I have been able to get under there to tighten the clamps on my MRTs without the lift but it was not cozy |
02-26-2014, 09:09 PM | #10 |
Ok thanks!
02-26-2014, 11:25 PM | #11 |
Unless you are a bigger fella, you shouldn't need any jacks. I installed my SLP LM2's without jacks
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
02-26-2014, 11:25 PM | #12 |
No lifting is required to get under and cut your mufflers off and install the new axle back
02-26-2014, 11:26 PM | #13 |
Drives: VR 2012 RS Join Date: Feb 2014
I'm undecided on this exhaust, once installed let us know your review
02-27-2014, 04:36 AM | #14 |
having FUN now 13.66@101
Yes, you should be able to install them without putting in the air. Will it be easy, probably not. I used some ramps I madeout of 2 x 8.
I bought a SAWZALL just for this cut. Figured I could always use one, and have used it a few times since too. Buy one and keep it for future use instead of renting one. Be sure to look into welding them on when done. Which case find a good muffler shop and have them install them for under $100. No saw required, no jack stands required. However, no self satisfaction of doing it yourself either. And no jack stands or sawzall for future use. Choice is yours.
