01-24-2018, 06:36 PM | #1 |
1bad6
Drives: 2010 camaro Join Date: Sep 2017
Questions about loudness
Mrt v1, manual v6
The question is: i want to mak it louder, i want to wait before i do headers for warranty to expire I have heard there are 4 cats, and also resonators, one thing i am open to is doing the magnaflow x pipe, what can i do to make my car louder? Is there a way to get rid of the 4 cats, and would that make it louder?
Mods: trifecta tune on 93 pump gas, mrt v1 Axle-Back, drilled/slotted rotors, 4" quad tips, Res delete, big worm gfx black out kit all around, interior footwell lights.
01-24-2018, 07:01 PM | #2 | |
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
01-24-2018, 08:01 PM | #3 | |
1bad6
How does the headers get rid of the cats?
01-24-2018, 08:20 PM | #4 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
they replace the cats with tubing... You can have a high flow cat or an off road connection behind that. How do you have a warranty if you have a 2010?
2011 2SS/RS built 8/24/10
01-24-2018, 08:38 PM | #5 |
1bad6
Had a new 6 put in it, it came with a 2 yr warranty
01-24-2018, 09:54 PM | #6 |
Ahh, didn't see you were V6. Not sure how those cats are mounted or the stock exhaust setup.
On the LS3/L99, the cats are connected to the stock exhaust manifold.
01-24-2018, 09:56 PM | #7 |
1bad6
I havw no idea man that's what i'm trying to figure out
01-24-2018, 10:09 PM | #8 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
Dude just search/do research, there are literally hundreds of threads regarding header swaps.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
01-24-2018, 10:21 PM | #9 |
1bad6
Can't find it
01-24-2018, 11:04 PM | #10 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Real sound improvement will only come from changing out the headers, assuming shorties are your only option if you're waiting for the warranty. Research in the v6 engine, exhaust, and bolt-on's thread for how your header set up comes on the car. Then either get rid of the cats or get high flow ones. Still want it louder? Ditch the axleback and get a full 3in catback. Most will offer small performance gains and delete the factory resonator as well as replace the h pipe with some sort of x pipe.
Assuming you're talking about the Magnaflow resonated x pipe, do not do this. It will make your car quieter. Without adding a catback, messing with the stock h pipe is pointless.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
01-24-2018, 11:25 PM | #11 | |
1bad6
I was going to save the x pipe for the headers, i have bbk long tube headers, i'm just extremely confused about the whole cats thing, the cats that have two on both sides, the headers come with these tiny little pipe things, how does that get rid of the cats? That's what i'm not understanding
01-25-2018, 03:45 AM | #12 | |
01-25-2018, 09:40 AM | #13 |
Drives: 2010 Camaro SS/RS - IOM - LS3 Join Date: Aug 2015
Thats a great find Gun.
01-25-2018, 12:01 PM | #14 | |
Drives: 2014 Camaro 2LS Join Date: Nov 2015
And going louder on a V6 isn't always better. Exhausts sound good to a certain point, then they become obnoxious and horrible sounding.
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
