Old 03-20-2024, 11:41 AM   #1
Jakub1999
Jakub1999's Avatar
Drives: Camaro 2016 RS
Leak
Hello,
I noticed that on the right side of the engine cover, there's a stain. Upon touching it it seems somewhat oily, but I'm not sure. Relatively, everything looks dry, but I touched those two hoses that I marked in the photo, and they are "wet". Is anyone able to roughly locate the issue?
I had the coolant replaced at the service center two months ago, but I'm not sure if it could be related to that.
Best regards.
Jakub1999 is offline   Reply With Quote
Old 03-20-2024, 12:26 PM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
when you touched it you then looked at your hand...what color was the fluid?
Old 03-20-2024, 01:48 PM   #3
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
I would clean up everything, document the color, smell, taste (jk), etc. Paper towels are handy for seeing color.
Then monitor. There is a mess down there and it's hard to tell where it's coming from. Now that you can look daily or after every drive.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Old 03-20-2024, 04:35 PM   #4
Jakub1999
Jakub1999's Avatar
Light brown, with a texture reminiscent of oil. In another thread, someone suggested that it could be from the transmission oil cooler
Old 03-20-2024, 05:22 PM   #5
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Those crimped pipes end up leaking sometimes. They probably need to be replaced.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Dynamical is offline   Reply With Quote
Old 03-20-2024, 10:00 PM   #6
ZLElvira
Waiting 4 A Point By!
ZLElvira's Avatar
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon
I recently had the fitting at the transmission Aux cooler leaking and replaced the o-ring. It was letting a little bit of oil to stream exactly where you are indicating.
ZLElvira is offline   Reply With Quote
Old 03-21-2024, 10:06 AM   #7
ctrlz
Those do look like lines to the radiator for transmission fluid cooling.
I would try to figure out which one is leaking, as I doubt both are. Maybe wrap them both in white paper towels held by zip ties. See how long they take to saturate, and maybe you'll get an idea if one or both are leaking, not to mention how MUCH they are leaking.
