01-26-2011, 11:50 AM | #1 |
Drives: 2010 IBM Camaro SS Join Date: Jun 2007
Headlight adjustment screws?
I couldnt find anything on this.. I have the non-RS headlights and am wondering if they have any adjustment ability. (vertical or horizontal)
Some of my previous cars could do this, how bout the Camaro?
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
01-26-2011, 11:52 AM | #2 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Yes it can. If you remove the front fascia you will see two screws coming out of the headlights. One vertical and one horizontal. Righty tighty lefty loosey
01-26-2011, 11:54 AM | #3 |
Have to remove the whole thing? (bumper etc?) I guess its all once piece. That seems an odd design for something that an average owner might need to adjust sometimes.
01-26-2011, 12:00 PM | #4 |
Yep whole front bumper. Its not that bad. Took me an hour and a half ish give or take. I don't think I would call adjusting the headlight orientation something that an average owner would do. More of a dealership thing I'd guess. That and unless you wrecked their shouldn't be a reason they went out of alignment to begin with.
01-26-2011, 12:19 PM | #5 |
Cool, mine seem to be aimed just a touch lower than I like. I'm hoping I can aim them up a small bit so they light the road ahead a bit better.
01-26-2011, 12:25 PM | #6 |
OK I might suggest taking your car to a automotive lighting shop. Just to be safe.
05-14-2011, 04:25 PM | #7 |
Drives: 2016 2SS Camaro Join Date: Mar 2010
Where is the adjustment? on the back of the headlight???
05-14-2011, 04:30 PM | #8 |
Yes. But like I have said previously. There is NO reason as to why you should be touching the adjustment screws.
05-14-2011, 04:43 PM | #9 |
Drives: Synergy Green 2SS/RS/HURST Join Date: Aug 2010
Unless you wrecked you car the headlights are set perfectly at the factory any adjustments you make will take them out of spec and open you up to possibly blinding someone coming at you and worse than that you could get ticketed or fail an inspection for them being improperly adjusted. Leave them alone.
2011 2SS/RS - Factory Hurst - Synergy Green - Cyber Gray Rally Stripes - Jet Black Interior - Born on 10/4/2010
2G1FT1EW7B9128807 Ordered: 8/6/2010 1100: 8/6/2010 2000: 8/23/2010 2051: 8/10/2010 2500: 8/24/2010 3000: 8/25/2010 3100: 9/8/2010 3300: 9/8/2010 3400: 9/11/2010 3800: 10/4/2010 4000: 10/4/2010 4200: 10/4/2010 5000: 10/13/2010 6000: 10/14/2010 |
05-14-2011, 07:01 PM | #10 | |
Madman
this
06-23-2011, 02:49 PM | #11 |
If anyone reads this post in the future. YOU DO NOT HAVE TO REMOVE THE FRONT BUMPER TO ADJUST VERTICAL ANGLE OF YOUR HEADLIGHTS.
Adjustment knob is behind the Headlight and uses a hex bolt. Looks like a white cone sticking straight up. Attached to headlight |
06-23-2011, 06:09 PM | #12 |
66ford pickup
Drives: Still lookin for a camaro Join Date: Apr 2011
but if you need to do the horizantal ones... then it has to come off lol. but to the OP there should be 2 screws holding the lamp and a spring as the counter.
1966 F100 352 V8 white/blue |
06-23-2011, 06:34 PM | #13 | |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
well, good job not listening to someone telling you to remove the whole front fascia to adjust the headlight |
06-24-2011, 07:04 AM | #14 |
There is no horizontal HL adjustment on the 2010 camaro non-RS. only vertical behind headlight
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Headlight Armor Lighting Protection and Smoked Taillight Kits Available | HeadlightArmor | Exterior Parts & Accessories | 1597 | 12-31-2019 01:52 PM |
Restoring Headlights with Headlight Armor Lighting Protection | HeadlightArmor | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 01-12-2016 11:58 AM |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
BMW Headlight Conversion *video added* | wylde1 | Cosmetics and Lighting Modification Discussions | 110 | 05-29-2013 10:02 AM |
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! | Wes@Flashtech | Exterior Parts & Accessories | 51 | 09-27-2010 08:19 PM |
