Old 12-13-2017, 03:46 PM   #1
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Lower pulley swap question
Does anyone know if you have to remove the radiator or the ac lines to do a lower pulley swap on a 2017 A10. Thanks for the help
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 12-13-2017, 05:26 PM   #2
Jonathon533
Drives: 2017 ZL1
Radiator- no. Lines and fan-yes
Jonathon533 is offline   Reply With Quote
Old 12-13-2017, 05:36 PM   #3
Victoryred1le
Bupp Motorsports
Victoryred1le's Avatar
Drives: 2017 Summit White ZL1 A10
+1
Victoryred1le is offline   Reply With Quote
Old 12-13-2017, 10:05 PM   #4
TDS
TDS's Avatar
Thanks for the info. I did not know that the AC lines had to be removed. Just wanted to confirm I was not being told something that was not true. Thanks for the info!!!!
Travis
Old 12-13-2017, 10:30 PM   #5
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Is there an install guide to follow somewhere? With the AC lines having to come off does that mean we need to get a recharge of the new $500+ refrigerant?
djfury05 is offline   Reply With Quote
Old 12-13-2017, 10:54 PM   #6
Sinester17
Drives: 2017 Summit white ZL1 M6
a shop should be able to evacuate the Freon and replace your system with your own Freon, leaving you paying only for labor.
Sinester17 is offline   Reply With Quote
Old 12-13-2017, 11:26 PM   #7
Zl1steve
Drives: Zl1
I did mine without messing with the ac lines.
Zl1steve is offline   Reply With Quote
Old 12-14-2017, 10:36 PM   #8
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Did you just pull the fan? I’ve been debating between upper and lower pulleys. I wasn’t sure how tough the lower would be on a ZL1.
BMWM.D. is offline   Reply With Quote
Old 12-15-2017, 01:05 AM   #9
Zl1steve
Drives: Zl1
Pulled fan. Not a hard job at all.
Old 12-15-2017, 06:49 AM   #10
McBrayer
Drives: 2017 ZL1
It can easily be done by pulling the fan and radiator. The A/C line DO NOT have to be touched.
FYI the crankshaft dampener bolt is a SINGLE USE bolt. You will need to have a GM replacement on hand when changing the dampener. I had to slightly torch heat the factory bolt to get it to break loose.
McBrayer is offline   Reply With Quote
Old 12-15-2017, 09:22 AM   #11
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Do you guys have manual cars or the A10? I’ve done cam swaps on LS motors, so I know the drill with the crank bolt and press fit pulley. But all the cars I’ve done have been M6 cars. I’m assuming I’ll have to remove the starter and get a flexplate locking tool to do the crank pulley on my A10 car.
Was there room to get an impact gun in there with just the fan removed?
Old 12-15-2017, 01:53 PM   #12
djfury05
djfury05's Avatar
Yea if somebody could explain the whole process for an A10 that'd be appreciated. I do all my own work but haven't touched a 6th gen yet and can't find any guides on it.
Old 12-15-2017, 11:14 PM   #13
zackf80m
Drives: Camaro ZL1
Fair warning; the factory 6th gen ZL1 bolt doesn't fit with ATI lower, at least with the 15%. I fitted my 15% with an ARP bolt from a c7 z06 innovators west kit, apparently a LS7 or 5th gen camaro bolt will fit as well!
zackf80m is offline   Reply With Quote
Old 12-15-2017, 11:49 PM   #14
djfury05
djfury05's Avatar
Oh well that's cool right after a replacement crank bolt arrived yesterday. Any other issues?
