11-20-2017, 11:21 PM | #1 |
Drives: 2014 SS - Sleeved 427/Procharged Join Date: Mar 2017
Engine Oil
Call me stupid for asking this, the oil weight GM specifies to load into the 6.2 L99/LS3 is 5W-30. I've gone by this standard ever since I got my Camaro. I've been seeing AMSOIL advertisements about putting much higher weight oil into racing (built, blown, stroked, bored etc.) engines. My L99 block is converted to an LS3 (LS7 lifters, new trays, new chain, etc.) and is cammed with a Procharger as well. Would it be alright, and maybe even wise to run a heavier oil such as 10W-30, which is the lowest weight AMSOIL Dominator Oil (which is the one I'm leaning towards) comes in. If so, would anyone recommend a certain weight for this application? My engine spins out to nearly 7,000rpm at WOT and hearing about what the wrong oil does makes me kinda squeamish. Thanks - Vis.
11-21-2017, 08:09 AM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
I'm sure there's a thousand threads on this very subject, but here's my shadetree/old dude two cents. Yes, you can run a 10W-30 with no issue. It's not that much of a difference to create problems like the bearings not getting the proper flow of oil. I wouldn't run something like the 50W's other owners here are sometimes running in their LS3's, unless the motor was built with bearing clearances to match that heavy an oil.
What did the shop you had the cam and blower installed recommend? Overall, the most important thing is you run a quality oil, and you change it and the filter commensurate with how freaking hard you run that bitch
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
11-21-2017, 08:40 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
You're fine. The first number is for cold start viscosity and you wouldn't be high-revving while it's cold anyway. You'd be well within the 30 spec before the engine is putting stress. Just take it easier in the colder mornings if you have them.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
11-21-2017, 09:37 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
In Amsoil's line for you I'd recommend 10w30 Zrod.
Dominator is their racing oil. Racing oils require very frequent oil change intervals as they do not have the detergents needed for typical street/performance car use. Zrod has the higher zinc/phos, plus the detergents needed for a good street/performance oil. 10w30 is fine, unless going to be in really low below freezing temps, then I'd use 5w30 Signature Series. |
11-21-2017, 10:08 AM | #5 |
Thanks for the replies guys. I'll look into the Z-Rod oil
11-21-2017, 11:34 AM | #6 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
0/40 Mobile one euro formula , works great .
OLD GUY FLYING FAST AND LOW
11-21-2017, 02:00 PM | #7 | |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
This is exactly what I run. Good oil. |
11-21-2017, 05:45 PM | #8 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
look into driven racing oil specifically made for a modified LS engine I use LS30.......our oiling is a system specifically made for lighter weight oils as to not starve the top end....very important for wear on start up. I order my oil and pick it up from my local baxter auto supply, lots of old school guys use driven racing oil so its sold from the stock at the warehouse and not just something you see on a shelf usually unless its a break in oil ...which they sell a lot of..you will find nothing better than Driven if you read up things like MPAO matter and you will hear about it and sheer and ZDDP etc.....
And BTW its recommended by god himself if you read the endorcements its like every cam and bearing maker etc etc.......... And BTW many raise their top redline on their tune......not something I did or will do, the ls7 has a higher limit thanks to 1.8 rockers( thus less lift on the cam even built) , serious money for a good top end to go higher when your most likely far into diminished returns when looking at a dyno chart for a ls3 typical cams bought for street strip up to stage 4....++++ and most makers only test their springs to 7k BTW............. Anyway you could just use what ever for oil, amsoil is pretty good if you look at their comparison of synthetic online in a study, but the costs and the no way I am running oil for 10k....let alone its not made more engine specific like the driven......well lots of things made me choose my oil and studying things helps. And yes I do a break in with br30....and read the tech and bulletin articles as they care as the info comes from racers as the oil was born from NASCAR and its needs.....Joe Gibbs etc and making a 400% improvement in break in /longevity.... yup some awesome testimonials of people finishing races with their oil and no pressure.....etc
11-23-2017, 01:36 AM | #9 |
11-23-2017, 04:43 AM | #10 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Food for thought.
www.camaro5.com/forums/showthread.php?t=466584 www.camaro5.com/forums/showthread.php?t=511832
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
11-23-2017, 04:53 PM | #11 |
11-23-2017, 07:04 PM | #12 | |
Drives: ‘13 1LE Join Date: Jul 2013
For you to kick things off, 10w/30, choose your poison, can't go wrong man. Do oil analysis if racing hard, move up accordingly |
11-23-2017, 09:47 PM | #13 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I would use 0w-40 or 5w-40. Mobil 1 turbo diesel truck is SN rated for gas use and is a great oil. Just don't rev the motor until the oil gets up to temp with the low pressure bypass valves (1 in the pan for AFM, 1 in the oil pump). Do an oil analysis after running a 30 and 40 for at least 3000 miles. For true apple to apples the Si (silicon) levels need to be same for both samples. Silicon measures dirt, which is the biggest cause of wear no matter what oil you use, so a good air filter and tight plumbing critical.
12-11-2017, 02:14 PM | #14 |
Will do
Thread Tools | |
