10-29-2017, 09:39 PM | #1 |
drilled rotors
Wondering if anyone has changed to a drilled or slotted rotor?
10-29-2017, 10:02 PM | #2 |
Under a Peterbilt
Drives: Rogue, Durango and Camaro Join Date: Jul 2009
Slotted=good for track
Drilled=good for street and car shows
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
10-29-2017, 10:49 PM | #3 |
I see where others are asking about different types of pads, was wondering if anyone had tried a different rotor, if they are running on the track.
10-29-2017, 11:36 PM | #4 |
Under a Peterbilt
A drilled rotor runs the risk of breaking apart from heat on the track. The holes hurt the function of the rotor itself. I have drilled and slotted rotors on my car, but I don't track the car at all. A DBA slotted rotor would be your best best.
10-30-2017, 07:46 AM | #5 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
R1 Concepts Premier Slotted. Track the car from time to time, so wanted to stay away from drilled or drilled/slotted. Running OEM pads right now, see no reason to change yet.
I would have expected this to be an easy searchable subject in the Wheel/Brakes/Suspension section.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
10-30-2017, 12:54 PM | #6 |
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE Join Date: May 2012
Slotted or blanks for the track. I've used the factory rotors for 2 years with Wilwood ProMatrix pads for track duty without issues. Went with slotted StopTech rotors for the front this year, with blanks on the rear. Ran GLoc pads front and rear and was basically all track duty. Warped the front rotors pretty hard at NCM during the Optima Search for the Ultimate Street Car event only because of another car catching fire at the top of a hill and we were stuck on the hill from it. Otherwise the rotors were just fine and no issues with them or the pads from the track duty. As stated, keep the drilled rotors for the car shows and street.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery, Hooker Headers Blackheart exhaust,Powerbrake InstaGram & Twitter: @jlouie62 FB: hangtimeracing |
10-30-2017, 09:27 PM | #7 |
And now I know! Thanks for the info everyone.
10-31-2017, 08:37 AM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I got recommended these by a garage at the track:
Gyrodisc. Good reputation apparently and the rotors are lighter than stock. Slotted, not drilled. I ended up doing the CTS-V upgrade. Had to replace my front hubs too, the right was completely done at 40K miles + track use. I replaced with ZL1/1LE/CTS-V spec SKF hubs.
12-02-2017, 09:19 PM | #9 |
Drives: 2015 2SS/RS 1LE G7C, Join Date: Nov 2015
I went with Baer Decela Sports front & back. Wanted improved looks at the lowest end of the cost scale, any braking improvements a bonus. DIY install with a buddy was a piece of cake.
12-08-2017, 10:06 PM | #10 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
What about dimpled rotors for track use?
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
12-09-2017, 09:01 PM | #11 |
Drives: Camaro Justice Join Date: Jun 2007
We use OEM rotors and G-LOC or CobaltFriction pads.
12-24-2017, 03:55 PM | #12 |
One more question on brakes. Had the wheels off doing some cleaning and notice four little steel casters on each front brake caliper. What are they and what do they do? Thanks
12-24-2017, 03:57 PM | #13 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
They are referred to as roller skates and I believe their only purpose is to combat brake noise
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
12-24-2017, 05:57 PM | #14 |
Looks like a lot for brake noise, but ok ill go with it. Thanks for the info, Merry Christmas
